주요 콘텐츠로 건너뛰기
Torque King Electric RTR RC Monster Truck Antenna Replacement
필요한 것
  1. Torque King Electric RTR RC Monster Truck Antenna Replacement, Casing: 1 단계, 이미지 1/2 Torque King Electric RTR RC Monster Truck Antenna Replacement, Casing: 1 단계, 이미지 2/2
    • From the top view, remove each of the four pins that hold the casing in place.
  2. Torque King Electric RTR RC Monster Truck Antenna Replacement: 2 단계, 이미지 1/1
    • Slowly pull the casing up to remove it.
  3. Torque King Electric RTR RC Monster Truck Antenna Replacement, Loosen Screw: 3 단계, 이미지 1/1
    • Loosen the 10mm screw surrounded by the copper using a #2 Phillips head screwdriver.
    • The wire that connects the antenna to the circuitry of the truck might be blocking the screw. Take care when moving the wire out of the way not to pull it from its soldering.
  4. Torque King Electric RTR RC Monster Truck Antenna Replacement, Remove Antenna: 4 단계, 이미지 1/1
    • Carefully slide the antenna out from under the screw and remove.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Colton Sholtis
회원 가입일: 01/30/15
257 평판
안내서 2개 작성하였습니다
Cal Poly, Team 6-30, Amido Winter 2015 Cal Poly, Team 6-30, Amido Winter 2015 회원
CPSU-AMIDO-W15S6G30
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 13
전체 시간: 521
