주요 콘텐츠로 건너뛰기
Torque King Electric RTR RC Monster Truck Battery Replacement
필요한 것
  1. Torque King Electric RTR RC Monster Truck Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Beginning at the bottom of the truck, twist the release clip on the casing until the release clip is no longer covering the battery casing.
  2. Torque King Electric RTR RC Monster Truck Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Next, use a Phillips 00 screwdriver to remove the 8mm screw on the battery casing and remove the battery casing.
  3. Torque King Electric RTR RC Monster Truck Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Do not skip this step if you are continuing onto the next step, you will risk electric shock.
    • Finally, remove the battery from the white connector by squeezing the clip on the connector while pulling.
결론
작성자
4다른 기여자 명과 함께
Thomas White
회원 가입일: 02/02/15
252 평판
안내서 2개를 작성함
Cal Poly, Team 6-30, Amido Winter 2015 Cal Poly, Team 6-30, Amido Winter 2015 회원
CPSU-AMIDO-W15S6G30
4 회원들
안내서 16개를 작성함
1가이드 댓글
Heeft u ook een suggestie om de oplaadbare batterij geheel te vervangen als hij niet meer oplaadt? Einde levensduur..
Kun je daar zomaar een andere oplaadbare batterij in steken (openknippen en contactpunten opnieuw vastzetten?
Of kun je eventueel een ‘gewone’ 9V batterij in plaats van de die oplaadbare, verbinden? Dus kabeltje doorknippen en een 9V stekkertje plaatsen?
Dank u.
Franq - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 12
전체 시간: 691
