주요 콘텐츠로 건너뛰기
Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement
필요한 것
  1. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement, Casing: 1 단계, 이미지 1/2 Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement, Casing: 1 단계, 이미지 2/2
    • From the top view, remove each of the four pins that hold the casing in place.
  2. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement: 2 단계, 이미지 1/1
    • Slowly pull the casing up to remove it.
  3. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement, Removing Screws: 3 단계, 이미지 1/1
    • Using a Phillips 1 screwdriver, completely unscrew the 8mm screw located in the center of the wheel. Repeat this step for other wheels if needed.
  4. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement, Removing the Wheel: 4 단계, 이미지 1/1
    • Carefully pull the wheel off of its axle. Repeat for other wheels as necessary.
  5. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement, Front Wheel Suspension: 5 단계, 이미지 1/2 Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement, Front Wheel Suspension: 5 단계, 이미지 2/2
    • Pull the top half of the suspension to unclip it.
  6. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement: 6 단계, 이미지 1/1
    • Remove the top clip along with the spring.
  7. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement: 7 단계, 이미지 1/2 Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement: 7 단계, 이미지 2/2
    • Pull up the bottom half of the suspension to unclip it.
결론
Maximiliano Cortes
회원 가입일: 02/01/15
418 평판
안내서 3개 작성하였습니다
Cal Poly, Team 6-30, Amido Winter 2015 Cal Poly, Team 6-30, Amido Winter 2015 회원
CPSU-AMIDO-W15S6G30
4 회원들
안내서 16개 작성하였습니다
댓글 한 개
Hola buenas noches, me pueden hacer el favor de ayudarme a armar de nuevo la parte de la suspensión de la parte delantera, te go todas las piezas pero no recuerdo como van
Vivian giseli Barrero - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 288
