주요 콘텐츠로 건너뛰기
Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement
필요한 것
  1. Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement, Casing: 1 단계, 이미지 1/2 Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement, Casing: 1 단계, 이미지 2/2
    • From the top view, remove each of the four pins that hold the casing in place.
  2. Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement: 2 단계, 이미지 1/1
    • Slowly pull the casing up to remove it.
  3. Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement, Removing Screws: 3 단계, 이미지 1/1
    • Using a Phillips 1 screwdriver, completely unscrew the 8mm screw located in the center of the wheel. Repeat this step for other wheels if needed.
  4. Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement, Removing the Wheel: 4 단계, 이미지 1/1
    • Carefully pull the wheel off of its axle. Repeat for other wheels as necessary.
  5. Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement, Rear Wheel Suspension: 5 단계, 이미지 1/1
    • After removing the rear wheels, remove the 8mm screw under each spring with a Phillips 1 screwdriver.
  6. Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement: 6 단계, 이미지 1/1
    • Slide off the bottom part of the rod connected to the chassis.
  7. Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement: 7 단계, 이미지 1/3 Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement: 7 단계, 이미지 2/3 Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement: 7 단계, 이미지 3/3
    • Pull the black washer inside the spring downwards and towards the truck's rear simultaneously in order to remove the suspension.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Colton Sholtis
회원 가입일: 01/30/15
257 평판
안내서 2개 작성하였습니다
Cal Poly, Team 6-30, Amido Winter 2015 Cal Poly, Team 6-30, Amido Winter 2015 회원
CPSU-AMIDO-W15S6G30
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 189
