소개
Check to see if anything is obstructing the wheel before referring to this guide.
필요한 것
Using a Phillips 1 screwdriver, completely unscrew the 8mm screw located in the center of the wheel. Repeat this step for other wheels if needed.
Carefully pull the wheel off of its axle. Repeat for other wheels as necessary.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
