주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Toshiba A1304T Camera Replacement
필요한 것
  1. Toshiba A1304T Camera Replacement, Back panel: 1 단계, 이미지 1개 중 1개
    • Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located on the back panel.
  2. Toshiba A1304T Camera Replacement: 2 단계, 이미지 1개 중 1개
    • With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
    • The T8 Torx Security Bit Screwdriver can be substituted with a small flathead screwdriver. Screw removal may be slightly more difficult however.
  3. Toshiba A1304T Camera Replacement: 3 단계, 이미지 2개 중 1개 Toshiba A1304T Camera Replacement: 3 단계, 이미지 2개 중 2개
    • If needed, use the flathead screwdriver to gently pry the panel from the phone.
    • Using your fingers, lift the panel from the device.
  4. Toshiba A1304T Camera Replacement, Camera: 4 단계, 이미지 2개 중 1개 Toshiba A1304T Camera Replacement, Camera: 4 단계, 이미지 2개 중 2개
    • Using a small Phillips screwdriver, remove the two black screws from the positions indicated.
    • Gently pull the silver plate from the phone using your fingers.
  5. Toshiba A1304T Camera Replacement: 5 단계, 이미지 3개 중 1개 Toshiba A1304T Camera Replacement: 5 단계, 이미지 3개 중 2개 Toshiba A1304T Camera Replacement: 5 단계, 이미지 3개 중 3개
    • Using the head of a flathead screwdriver, flip the white segment of the socket that the camera's ribbon-wire runs into so that it is orientated vertically.
    • Gently lift the camera from its cavity and pull it away from the socket using your thumb and forefinger.
결론
작성자
4다른 기여자 명과 함께
Christopher
회원 가입일: 04/22/10
90 평판
안내서 8개를 작성함
Cal Poly, Team 16-6, Maness Spring 2010 Cal Poly, Team 16-6, Maness Spring 2010 회원
CPSU-MANESS-S10S16G6
4 회원들
안내서 17개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 28
지난 30일: 74
전체 시간: 2,338
