메인 콘텐츠로 스킵하기
소개
Use this guide to replace your Toshiba AT1304T keypad
  1. Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located on the back panel.
    • Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located on the back panel.
  2. With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
    • With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
    • The T8 Torx Security Bit Screwdriver can be substituted with a small flathead screwdriver. Screw removal may be slightly more difficult however.
  3. 아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
    아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
  4. If needed, use the flathead screwdriver to gently pry the panel from the phone. Using your fingers, lift the panel from the device.
    • If needed, use the flathead screwdriver to gently pry the panel from the phone.
    • Using your fingers, lift the panel from the device.
  5. Use your fingers to detach the ribbon wire located on the top of the logic board, as shown. Use your fingers to detach the ribbon wire located on the top of the logic board, as shown. Use your fingers to detach the ribbon wire located on the top of the logic board, as shown.
    • Use your fingers to detach the ribbon wire located on the top of the logic board, as shown.
  6. Use a flathead screwdriver to gently pry the logic board and keypad from the device. Use a flathead screwdriver to gently pry the logic board and keypad from the device.
    • Use a flathead screwdriver to gently pry the logic board and keypad from the device.
  7. Peel the keypad from the logic board using your thumb. Peel the keypad from the logic board using your thumb.
    • Peel the keypad from the logic board using your thumb.
결론
Christopher
회원 가입일: 2010년 04월 22일
90 평판
안내서 8개 작성하였습니다
Cal Poly, Team 16-6, Maness Spring 2010 Cal Poly, Team 16-6, Maness Spring 2010 회원
CPSU-MANESS-S10S16G6
4 회원들
안내서 16개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 1,588
