주요 콘텐츠로 건너뛰기
Toshiba A1304T Logic Board Replacement
필요한 것
  1. Toshiba A1304T Logic Board Replacement, Back panel: 1 단계, 이미지 1/1
    • Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located on the back panel.
  2. Toshiba A1304T Logic Board Replacement: 2 단계, 이미지 1/1
    • With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
    • The T8 Torx Security Bit Screwdriver can be substituted with a small flathead screwdriver. Screw removal may be slightly more difficult however.
  3. Toshiba A1304T Logic Board Replacement: 3 단계, 이미지 1/2 Toshiba A1304T Logic Board Replacement: 3 단계, 이미지 2/2
    • If needed, use the flathead screwdriver to gently pry the panel from the phone.
    • Using your fingers, lift the panel from the device.
  4. Toshiba A1304T Logic Board Replacement, Logic Board: 4 단계, 이미지 1/3 Toshiba A1304T Logic Board Replacement, Logic Board: 4 단계, 이미지 2/3 Toshiba A1304T Logic Board Replacement, Logic Board: 4 단계, 이미지 3/3
    • Use your fingers to gently detach the ribbon wire from the logic board.
  5. Toshiba A1304T Logic Board Replacement: 5 단계, 이미지 1/2 Toshiba A1304T Logic Board Replacement: 5 단계, 이미지 2/2
    • Use the flathead screwdriver to pry the logic board and keypad from the device.
  6. Toshiba A1304T Logic Board Replacement: 6 단계, 이미지 1/2 Toshiba A1304T Logic Board Replacement: 6 단계, 이미지 2/2
    • Use your thumb to peel the keypad from the device.
결론
Christopher
회원 가입일: 04/22/10
90 평판
안내서 8개 작성하였습니다
Cal Poly, Team 16-6, Maness Spring 2010 Cal Poly, Team 16-6, Maness Spring 2010 회원
CPSU-MANESS-S10S16G6
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 2,596
