이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located on the back panel.
With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
If needed, use the flathead screwdriver to gently pry the panel from the phone.
Using your fingers, lift the panel from the device.
Use your fingers to gently detach the ribbon wire from the logic board.
Use the flathead screwdriver to pry the logic board and keypad from the device.
