주요 콘텐츠로 건너뛰기
Toshiba A1304T Main LCD Screen Replacement
필요한 것
  1. Toshiba A1304T Main LCD Screen Replacement, Front Cover: 1 단계, 이미지 1/1
    • Open the phone so that it matches the photos to the left.
    • Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located around the main LCD screen.
  2. Toshiba A1304T Main LCD Screen Replacement: 2 단계, 이미지 1/2 Toshiba A1304T Main LCD Screen Replacement: 2 단계, 이미지 2/2
    • With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
    • The T8 Torx Security Bit Screwdriver can be substituted with a small flathead screwdriver. Screw removal may be slightly more difficult however.
  3. Toshiba A1304T Main LCD Screen Replacement: 3 단계, 이미지 1/2 Toshiba A1304T Main LCD Screen Replacement: 3 단계, 이미지 2/2
    • Insert the head of a flathead screwdriver into the seam between the front cover and the phone.
    • Pry gently until the cover gives slightly to create a slightly wider opening. You may hear a distinct pop as you pry.
    • Remove the screwdriver and re-insert it into another portion of the seam. Continue making gaps around the cover of the phone until it is completely detached from the body.
  4. Toshiba A1304T Main LCD Screen Replacement, Main LCD Screen: 4 단계, 이미지 1/2 Toshiba A1304T Main LCD Screen Replacement, Main LCD Screen: 4 단계, 이미지 2/2
    • Using the head of the flathead screwdriver, gently pry the black tab so that it rests in a vertical (or "unlocked") position.
    • Pull the orange ribbon-wire to the left, removing it from the white socket.
  5. Toshiba A1304T Main LCD Screen Replacement: 5 단계, 이미지 1/1
    • Just as before, use the head of the flathead screwdriver to pry the black tab into a vertical position, as shown.
    • Pull the ribbon wire to the right, freeing it from its socket.
  6. Toshiba A1304T Main LCD Screen Replacement: 6 단계, 이미지 1/2 Toshiba A1304T Main LCD Screen Replacement: 6 단계, 이미지 2/2
    • Using the head of the flathead screwdriver, pry the silver plastic casing of the LCD from the video logic board.
    • Repeat as necessary around the device until the silver plastic casing is free.
    • Attempting to further separate the LCD screen from the silver plastic casing will likely result in severe damage to the screen.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Christopher
회원 가입일: 04/22/10
90 평판
안내서 8개 작성하였습니다
Cal Poly, Team 16-6, Maness Spring 2010 Cal Poly, Team 16-6, Maness Spring 2010 회원
CPSU-MANESS-S10S16G6
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 1,659
