소개
If your Toshiba CB35-3350 Chromebook 2 is producing excessive noise, overheating, or the cooling performance is subpar, it may be a sign of a malfunctioning or broken internal fan. The fan helps the laptop stay within operating temperatures by removing heat from the internal components. A damaged or broken fan can result in overheating, reduced performance, or hardware failure.
This repair guide will provide a detailed step-by-step process to help you remove and replace the fan, allowing for optimal cooling performance. Before attempting to replace the battery, power off your Chromebook. Handle internal components delicately to avoid damage. Follow each step in order and refer back to this guide in the event of a problem or mishap.
필요한 것
Remove the eight Phillips #0 screws from the back panel of the laptop.
Use your hands and an iFixit opening tool to carefully pry and remove the back panel of the laptop.
