주요 콘텐츠로 건너뛰기
Toshiba CB35-C3300 Chromebook 2 Battery Replacement
필요한 것
  1. Toshiba CB35-C3300 Chromebook 2 Battery  Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Toshiba CB35-C3300 Chromebook 2 Battery  Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Remove the 2 rubber foot pads from the bottom (opposite the hinge) with the small Plastic Opening tool.
  2. Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: 2 단계, 이미지 2개 중 1개 Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the 10 7.1 mm screws using Phillips #1 screwdriver.
  3. Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: 3 단계, 이미지 1개 중 1개
    • Loosen the back cover by using a plastic opening tool all the way around the device.
    • There are areas all along the sides of the device that help aid in this.
    • Be careful when prying, and go slow. The silver plastic frame around the dull gray plastic bottom is fragile and easily dented from prying pressure.
  4. Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: 4 단계, 이미지 2개 중 1개 Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the back cover by gently lifting up on one side of the device.
    • The easiest side to lift up on is the one with the removed rubber foot pads.
  5. Toshiba CB35-C3300 Chromebook 2 Battery  Replacement, Battery: 5 단계, 이미지 2개 중 1개 Toshiba CB35-C3300 Chromebook 2 Battery  Replacement, Battery: 5 단계, 이미지 2개 중 2개
    • Remove the tape holding the speaker wire to the battery on both sides using a small opening tool.
  6. Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: 6 단계, 이미지 2개 중 1개 Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the 4 Phillips 3.2 mm screws holding the battery in place, with the Phillips #1 screwdriver.
  7. Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: 7 단계, 이미지 3개 중 1개 Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: 7 단계, 이미지 3개 중 2개 Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: 7 단계, 이미지 3개 중 3개
    • To disconnect the wire from the mother board, gently press down with the flat end of Spudger and pull on the wire.
    • Gently shaking the wire from left to right helps with the wire removal
  8. Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: 8 단계, 이미지 2개 중 1개 Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the battery by gently pulling on the bottom corners.
    • Be careful to move the battery's wire under the speaker's wire.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
varun kapadia
회원 가입일: 10/18/17
219 평판
안내서 1개를 작성함
USF Tampa, Team S1-G121, Cagle Fall 2017 USF Tampa, Team S1-G121, Cagle Fall 2017 회원
USFT-CAGLE-F17S1G121
3 회원들
안내서 14개를 작성함
1가이드 댓글
Thanks again IFIXIT!!! Repaced battery on Toshiba C35 C3300 with your HELP. Guy Rogers
Guy Rogers - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 10
전체 시간: 1,401
