주요 콘텐츠로 건너뛰기
Toshiba CB35-C3300 Chromebook 2 Display Replacement
필요한 것
  1. Toshiba CB35-C3300 Chromebook 2 Display Replacement, Display: 1 단계, 이미지 1개 중 1개
    • Start by opening your Chromebook and orient the computer as shown.
  2. Toshiba CB35-C3300 Chromebook 2 Display Replacement: 2 단계, 이미지 1개 중 1개
    • Using the opening tool, start at one of the two top corners and pull the faceplate away from the display.
    • Use the opening tool to work your way all the way around the frame.
  3. Toshiba CB35-C3300 Chromebook 2 Display Replacement: 3 단계, 이미지 1개 중 1개
    • Using a Jimmy, carefully pop the bottom of the faceplate away from the display.
  4. Toshiba CB35-C3300 Chromebook 2 Display Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the faceplate by pulling away from the keyboard.
  5. Toshiba CB35-C3300 Chromebook 2 Display Replacement: 5 단계, 이미지 1개 중 1개
    • Using an opening tool, start from one of the top corners of the screen and begin to pry it away from the top of the laptop.
    • Make sure that you can keep the foil on the Chromebook.
  6. Toshiba CB35-C3300 Chromebook 2 Display Replacement: 6 단계, 이미지 1개 중 1개
    • Using the Jimmy, remove the sticker holding the wire to this display.
  7. Toshiba CB35-C3300 Chromebook 2 Display Replacement: 7 단계, 이미지 1개 중 1개
    • Carefully remove the ribbon the display and remove the display from the Chromebook.
결론
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 9
전체 시간: 239
