주요 콘텐츠로 건너뛰기
Toshiba CB35-C3300 Chromebook 2 SSD Replacement
필요한 것
  1. Toshiba CB35-C3300 Chromebook 2 SSD Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Toshiba CB35-C3300 Chromebook 2 SSD Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Remove the 2 rubber foot pads from the bottom (opposite the hinge) with the small Plastic Opening tool.
  2. Toshiba CB35-C3300 Chromebook 2 SSD Replacement: 2 단계, 이미지 2개 중 1개 Toshiba CB35-C3300 Chromebook 2 SSD Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the 10 7.1 mm screws using Phillips #1 screwdriver.
  3. Toshiba CB35-C3300 Chromebook 2 SSD Replacement: 3 단계, 이미지 1개 중 1개
    • Loosen the back cover by using a plastic opening tool all the way around the device.
    • There are areas all along the sides of the device that help aid in this.
    • Be careful when prying, and go slow. The silver plastic frame around the dull gray plastic bottom is fragile and easily dented from prying pressure.
  4. Toshiba CB35-C3300 Chromebook 2 SSD Replacement: 4 단계, 이미지 2개 중 1개 Toshiba CB35-C3300 Chromebook 2 SSD Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the back cover by gently lifting up on one side of the device.
    • The easiest side to lift up on is the one with the removed rubber foot pads.
  5. Toshiba CB35-C3300 Chromebook 2 SSD Replacement, SSD: 5 단계, 이미지 1개 중 1개
    • Remove the translucent yellow tape that connects the Wi-Fi card and the SSD.
    • Using a Phillips #1 screwdriver, remove the single screw connecting the SSD to the motherboard.
  6. Toshiba CB35-C3300 Chromebook 2 SSD Replacement: 6 단계, 이미지 1개 중 1개
    • Gently grab the SSD and remove the card from the SSD slot on the motherboard, careful not to damage any of the connections on the motherboard.
결론
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 8
지난 30일: 24
전체 시간: 642
