주요 콘텐츠로 건너뛰기
Toshiba CB35-C3300 Chromebook 2 Speakers
필요한 것
  1. Toshiba CB35-C3300 Chromebook 2 Speakers, Back Cover: 1 단계, 이미지 1/2 Toshiba CB35-C3300 Chromebook 2 Speakers, Back Cover: 1 단계, 이미지 2/2
    • Remove the 2 rubber foot pads from the bottom (opposite the hinge) with the small Plastic Opening tool.
  2. Toshiba CB35-C3300 Chromebook 2 Speakers: 2 단계, 이미지 1/2 Toshiba CB35-C3300 Chromebook 2 Speakers: 2 단계, 이미지 2/2
    • Remove the 10 7.1 mm screws using Phillips #1 screwdriver.
  3. Toshiba CB35-C3300 Chromebook 2 Speakers: 3 단계, 이미지 1/1
    • Loosen the back cover by using a plastic opening tool all the way around the device.
    • There are areas all along the sides of the device that help aid in this.
    • Be careful when prying, and go slow. The silver plastic frame around the dull gray plastic bottom is fragile and easily dented from prying pressure.
  4. Toshiba CB35-C3300 Chromebook 2 Speakers: 4 단계, 이미지 1/2 Toshiba CB35-C3300 Chromebook 2 Speakers: 4 단계, 이미지 2/2
    • Remove the back cover by gently lifting up on one side of the device.
    • The easiest side to lift up on is the one with the removed rubber foot pads.
  5. Toshiba CB35-C3300 Chromebook 2 Speakers, Battery: 5 단계, 이미지 1/2 Toshiba CB35-C3300 Chromebook 2 Speakers, Battery: 5 단계, 이미지 2/2
    • Remove the tape holding the speaker wire to the battery on both sides using a small opening tool.
  6. Toshiba CB35-C3300 Chromebook 2 Speakers: 6 단계, 이미지 1/2 Toshiba CB35-C3300 Chromebook 2 Speakers: 6 단계, 이미지 2/2
    • Remove the 4 Phillips 3.2 mm screws holding the battery in place, with the Phillips #1 screwdriver.
  7. Toshiba CB35-C3300 Chromebook 2 Speakers: 7 단계, 이미지 1/3 Toshiba CB35-C3300 Chromebook 2 Speakers: 7 단계, 이미지 2/3 Toshiba CB35-C3300 Chromebook 2 Speakers: 7 단계, 이미지 3/3
    • To disconnect the wire from the mother board, gently press down with the flat end of Spudger and pull on the wire.
    • Gently shaking the wire from left to right helps with the wire removal
  8. Toshiba CB35-C3300 Chromebook 2 Speakers: 8 단계, 이미지 1/2 Toshiba CB35-C3300 Chromebook 2 Speakers: 8 단계, 이미지 2/2
    • Remove the battery by gently pulling on the bottom corners.
    • Be careful to move the battery's wire under the speaker's wire.
  9. Toshiba CB35-C3300 Chromebook 2 Speakers, Speakers: 9 단계, 이미지 1/2 Toshiba CB35-C3300 Chromebook 2 Speakers, Speakers: 9 단계, 이미지 2/2
    • Remove the 4 Phillip 6.3 mm screws from both the right and left speakers using Phllips 1 screwdriver.
  10. Toshiba CB35-C3300 Chromebook 2 Speakers: 10 단계, 이미지 1/1
    • Gently remove wire from the motherboard by pulling it out of the connector socket.
  11. Toshiba CB35-C3300 Chromebook 2 Speakers: 11 단계, 이미지 1/3 Toshiba CB35-C3300 Chromebook 2 Speakers: 11 단계, 이미지 2/3 Toshiba CB35-C3300 Chromebook 2 Speakers: 11 단계, 이미지 3/3
    • Remove the right and left speaker by lifting them up.
결론
Mehdi Mohammadi
회원 가입일: 10/18/17
416 평판
안내서 1개 작성함
USF Tampa, Team S1-G121, Cagle Fall 2017 USF Tampa, Team S1-G121, Cagle Fall 2017 회원
USFT-CAGLE-F17S1G121
3 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 11
전체 시간: 194
