주요 콘텐츠로 건너뛰기
Toshiba CB35-C3300 Chromebook 2 WLAN Wi-Fi PCB Replacement
필요한 것
  1. Toshiba CB35-C3300 Chromebook 2 WLAN Wi-Fi PCB Replacement, WLAN Wi-Fi PCB: 1 단계, 이미지 1개 중 1개
    • Remove the two rubber tabs near the front of the computer with a metal spudger and with PH0 Phillips head screwdriver, carefully remove all ten screws and place in a safe location.
  2. Toshiba CB35-C3300 Chromebook 2 WLAN Wi-Fi PCB Replacement: 2 단계, 이미지 1개 중 1개
    • Ensure that there is no debris, dust, or any other foreign materials blocking the Wi-Fi PCB.
  3. Toshiba CB35-C3300 Chromebook 2 WLAN Wi-Fi PCB Replacement: 3 단계, 이미지 1개 중 1개
    • Carefully peel back the yellow tape by either folding it back or removing it entirely. Use the same PH0 Phillips head screwdriver to remove the single screw that connects the motherboard to the Wi-Fi PCB.
  4. Toshiba CB35-C3300 Chromebook 2 WLAN Wi-Fi PCB Replacement: 4 단계, 이미지 1개 중 1개
    • When the screw has been removed, the board will naturally spring up. Carefully apply light pressure to back the PCB out of its port.
  5. Toshiba CB35-C3300 Chromebook 2 WLAN Wi-Fi PCB Replacement: 5 단계, 이미지 1개 중 1개
    • Disconnect the black wire that is plugged onto the 1 or AUX terminal by simply lightly pulling it from the board.
  6. Toshiba CB35-C3300 Chromebook 2 WLAN Wi-Fi PCB Replacement: 6 단계, 이미지 1개 중 1개
    • Disconnect the white wire from the 2 or Main plug by lightly pulling it from the PCB.
결론
작성자
1다른 기여자 명과 함께
Gabriel Bryan
회원 가입일: 11/26/18
303 평판
안내서 2개를 작성함
IUPUI, Team S6-G6, Wilson Fall 2018 IUPUI, Team S6-G6, Wilson Fall 2018 회원
IUPUI-WILSON-F18S6G6
3 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 4
전체 시간: 172
