주요 콘텐츠로 건너뛰기
Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement
필요한 것
  1. Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Remove the 2 rubber foot pads from the bottom (opposite the hinge) with the small Plastic Opening tool.
  2. Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: 2 단계, 이미지 2개 중 1개 Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the 10 7.1 mm screws using Phillips #1 screwdriver.
  3. Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: 3 단계, 이미지 1개 중 1개
    • Loosen the back cover by using a plastic opening tool all the way around the device.
    • There are areas all along the sides of the device that help aid in this.
    • Be careful when prying, and go slow. The silver plastic frame around the dull gray plastic bottom is fragile and easily dented from prying pressure.
  4. Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: 4 단계, 이미지 2개 중 1개 Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the back cover by gently lifting up on one side of the device.
    • The easiest side to lift up on is the one with the removed rubber foot pads.
  5. Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement, Battery: 5 단계, 이미지 2개 중 1개 Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement, Battery: 5 단계, 이미지 2개 중 2개
    • Remove the tape holding the speaker wire to the battery on both sides using a small opening tool.
  6. Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: 6 단계, 이미지 2개 중 1개 Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the 4 Phillips 3.2 mm screws holding the battery in place, with the Phillips #1 screwdriver.
  7. Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: 7 단계, 이미지 3개 중 1개 Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: 7 단계, 이미지 3개 중 2개 Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: 7 단계, 이미지 3개 중 3개
    • To disconnect the wire from the mother board, gently press down with the flat end of Spudger and pull on the wire.
    • Gently shaking the wire from left to right helps with the wire removal
  8. Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: 8 단계, 이미지 2개 중 1개 Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the battery by gently pulling on the bottom corners.
    • Be careful to move the battery's wire under the speaker's wire.
  9. Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement, Fan: 9 단계, 이미지 1개 중 1개
    • Locate the fan
  10. Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: 10 단계, 이미지 1개 중 1개
    • Unscrew the 4 Phillip screws using a Phillips # 1 Screwdriver.
    • These screws only loosen partially, they do not disconnect.
  11. Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: 11 단계, 이미지 3개 중 1개 Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: 11 단계, 이미지 3개 중 2개 Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: 11 단계, 이미지 3개 중 3개
    • The top wire is the fan's wire. Remove it by pulling it from the motherboard.
  12. Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: 12 단계, 이미지 3개 중 1개 Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: 12 단계, 이미지 3개 중 2개 Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: 12 단계, 이미지 3개 중 3개
    • To remove the Wifi PCB wire lift up the hinged flap with your finger or with the aid of the spudger tool.
    • After the flap is lifted, pull the wire up out of the connector socket.
  13. Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: 13 단계, 이미지 2개 중 1개 Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: 13 단계, 이미지 2개 중 2개
    • Remove the headphone jack wire by pulling it out of the connector socket.
  14. Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: 14 단계, 이미지 1개 중 1개
    • Remove the Phillip 3.6 mm screw from the fan using a Phillips #1 screwdriver.
  15. Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: 15 단계, 이미지 1개 중 1개
    • Lift up on the metal plate that hold the screws to start removing the fan.
  16. Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: 16 단계, 이미지 3개 중 1개 Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: 16 단계, 이미지 3개 중 2개 Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: 16 단계, 이미지 3개 중 3개
    • Once lifted, you will notice that there are two wires tucked under plastic tunnels on the right side of the fan. Remove these wires.
    • These wires require you to gently pull them out of there tunnel.
    • Once the wires are removed the fan should be removed entirely.
  17. Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement, WiFi PCB: 17 단계, 이미지 1개 중 1개
    • The WiFi PCB is located next to the fan.
  18. Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: 18 단계, 이미지 1개 중 1개
    • Remove the Phillips 3.7 mm screw using a Phillips #1 screwdriver.
  19. Toshiba CB35-C3300 Chromebook 2 WiFi PCB Replacement: 19 단계, 이미지 1개 중 1개
    • Gently remove the WiFi PCB by pulling upward.
결론
작성자
3다른 기여자 명과 함께
Jillian Thomas
회원 가입일: 10/14/17
209 평판
안내서 4개를 작성함
USF Tampa, Team S1-G121, Cagle Fall 2017 USF Tampa, Team S1-G121, Cagle Fall 2017 회원
USFT-CAGLE-F17S1G121
3 회원들
안내서 14개를 작성함
1가이드 댓글
The article has some mistakes, namely, this isn’t the WiFi / WLAN, it is a USB port and card reader slot PCB. I came to iFixIt to double-check the part to upgrade to WiFi 6 (ax). Once you fix the part name, the article is good! The part number DA0BUITH8D0 is what to search for when trying to buy one. I didn’t need one, but looked it up just the same, there are not a ton of these out there and I would probably just resort to a USB reader.
Vic Lovan - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 13
전체 시간: 483
