주요 콘텐츠로 건너뛰기
Toshiba Chromebook 2 Battery Replacement
필요한 것
  1. Toshiba Chromebook 2 Battery Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Remove all external devices from the Toshiba Chromebook 2.
  2. Toshiba Chromebook 2 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Close the Toshiba Chromebook 2 and turn it over so that the bottom of the laptop is facing upwards toward you with the lettering on the bottom facing right side up.
  3. Toshiba Chromebook 2 Battery Replacement: 3 단계, 이미지 2개 중 1개 Toshiba Chromebook 2 Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the 8 visible Phillips 8.25 mm screws using the Phillips #0 screwdriver.
  4. Toshiba Chromebook 2 Battery Replacement: 4 단계, 이미지 2개 중 1개 Toshiba Chromebook 2 Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Remove 2 hidden Phillips 8.25 mm screws located underneath the rubber grips at the back (opposite the hinges) with the Phillips #0 screwdriver.
    • The rubber grips are glued in place, so you'll need to peel them up with a spudger or other pry tool.
  5. Toshiba Chromebook 2 Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the back panel by pulling up on 2 adjacent corners.
  6. Toshiba Chromebook 2 Battery Replacement, Battery: 6 단계, 이미지 2개 중 1개 Toshiba Chromebook 2 Battery Replacement, Battery: 6 단계, 이미지 2개 중 2개
    • Remove the 4 Phillips 2 mm screws holding the battery in place with the Phillips #0 screwdriver.
  7. Toshiba Chromebook 2 Battery Replacement: 7 단계, 이미지 2개 중 1개 Toshiba Chromebook 2 Battery Replacement: 7 단계, 이미지 2개 중 2개
    • Press down on the white clip and softly pull the wires out of the port to disconnect battery from the motherboard.
  8. Toshiba Chromebook 2 Battery Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the battery by gently pulling up on the bottom corners.
결론
다른 50명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Foster Chaney
회원 가입일: 10/08/15
762 평판
안내서 1개를 작성함
IUPUI, Team 1-3, Hagerty Fall 2015 IUPUI, Team 1-3, Hagerty Fall 2015 회원
IUPUI-HAGERTY-F15S1G3
5 회원들
안내서 7개를 작성함
댓글 7개
does the cb30-b-103 battery also work with the cb30-b-104 series?
henrikahlberg94 - 답글
I had four screws holding down battery.
When re-installing cover, don’t get confused. There are two holes under rubber feet on side CLOSEST TO HINGES. These do not accept the two screws - put them on side AWAY FROM HINGES.
Bill Brasier - 답글
Good instructions, my chrome is back to normal again .
Alexander Slaven - 답글
Many thanks but now there’s no curser! What do I do?
Chris in UK
Chris Tighe - 답글
Thank you, easy to follow, works like a dream
steve smith - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 13
지난 30일: 37
전체 시간: 28,947
