주요 콘텐츠로 건너뛰기
Toshiba Chromebook 2 Touchpad Replacement
필요한 것
  1. Toshiba Chromebook 2 Touchpad Replacement, Back Cover: 1 단계, 이미지 1/1
    • Remove all external devices from the Toshiba Chromebook 2.
  2. Toshiba Chromebook 2 Touchpad Replacement: 2 단계, 이미지 1/1
    • Close the Toshiba Chromebook 2 and turn it over so that the bottom of the laptop is facing upwards toward you with the lettering on the bottom facing right side up.
  3. Toshiba Chromebook 2 Touchpad Replacement: 3 단계, 이미지 1/2 Toshiba Chromebook 2 Touchpad Replacement: 3 단계, 이미지 2/2
    • Remove the 8 visible Phillips 8.25 mm screws using the Phillips #0 screwdriver.
  4. Toshiba Chromebook 2 Touchpad Replacement: 4 단계, 이미지 1/2 Toshiba Chromebook 2 Touchpad Replacement: 4 단계, 이미지 2/2
    • Remove 2 hidden Phillips 8.25 mm screws located underneath the rubber grips at the back (opposite the hinges) with the Phillips #0 screwdriver.
    • The rubber grips are glued in place, so you'll need to peel them up with a spudger or other pry tool.
  5. Toshiba Chromebook 2 Touchpad Replacement: 5 단계, 이미지 1/1
    • Remove the back panel by pulling up on 2 adjacent corners.
  6. Toshiba Chromebook 2 Touchpad Replacement, Battery: 6 단계, 이미지 1/2 Toshiba Chromebook 2 Touchpad Replacement, Battery: 6 단계, 이미지 2/2
    • Remove the 4 Phillips 2 mm screws holding the battery in place with the Phillips #0 screwdriver.
  7. Toshiba Chromebook 2 Touchpad Replacement: 7 단계, 이미지 1/2 Toshiba Chromebook 2 Touchpad Replacement: 7 단계, 이미지 2/2
    • Press down on the white clip and softly pull the wires out of the port to disconnect battery from the motherboard.
  8. Toshiba Chromebook 2 Touchpad Replacement: 8 단계, 이미지 1/1
    • Remove the battery by gently pulling up on the bottom corners.
  9. Toshiba Chromebook 2 Touchpad Replacement, Speakers: 9 단계, 이미지 1/1
    • Remove the 2 3.3 mm screws holding the left and right speakers with the Phillips #0 screwdriver.
  10. Toshiba Chromebook 2 Touchpad Replacement: 10 단계, 이미지 1/3 Toshiba Chromebook 2 Touchpad Replacement: 10 단계, 이미지 2/3 Toshiba Chromebook 2 Touchpad Replacement: 10 단계, 이미지 3/3
    • Pull the red and white wires out of the socket above the left speaker to disconnect the speakers from the motherboard.
  11. Toshiba Chromebook 2 Touchpad Replacement: 11 단계, 이미지 1/1
    • Remove the speakers by lifting upwards.
    • Wiring connecting the left and right speakers may be taped to the top of the battery. Simply remove the tape to remove the speakers.
  12. Toshiba Chromebook 2 Touchpad Replacement, Touchpad: 12 단계, 이미지 1/2 Toshiba Chromebook 2 Touchpad Replacement, Touchpad: 12 단계, 이미지 2/2
    • Detach the ribbon cable connected to the motherboard by gently pulling near the top fold.
  13. Toshiba Chromebook 2 Touchpad Replacement: 13 단계, 이미지 1/1
    • Detach the ribbon cable connected to the touch pad by gently pulling near the bottom fold.
  14. Toshiba Chromebook 2 Touchpad Replacement: 14 단계, 이미지 1/2 Toshiba Chromebook 2 Touchpad Replacement: 14 단계, 이미지 2/2
    • Remove all four 3.70mm screws around the edges of the touchpad using a Phillips #0 screwdriver.
  15. Toshiba Chromebook 2 Touchpad Replacement: 15 단계, 이미지 1/2 Toshiba Chromebook 2 Touchpad Replacement: 15 단계, 이미지 2/2
    • Use the spudger to push up on the metal cover below the touch pad until it reaches 90 degrees then pull up to detach.
  16. Toshiba Chromebook 2 Touchpad Replacement: 16 단계, 이미지 1/3 Toshiba Chromebook 2 Touchpad Replacement: 16 단계, 이미지 2/3 Toshiba Chromebook 2 Touchpad Replacement: 16 단계, 이미지 3/3
    • Peel back the aluminum foil piece on the top right corner of the touchpad.
    • Move slowly and carefully, you will need the same aluminum foil piece to connect to your new touchpad.
  17. Toshiba Chromebook 2 Touchpad Replacement: 17 단계, 이미지 1/2 Toshiba Chromebook 2 Touchpad Replacement: 17 단계, 이미지 2/2
    • Push down on the bottom right corner and slowly lift up in the upper right hand corner until the touch pad comes out.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Haley Hattendorf
회원 가입일: 10/06/16
598 평판
안내서 2개 작성하였습니다
Cal Poly, Team 10-4, Livingston Fall 2016 Cal Poly, Team 10-4, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S10G4
4 회원들
안내서 11개 작성하였습니다
댓글 2개
Thanks for this guide! Worked perfectly.
Mathias Maes - 답글
This is great! I was able to save our school the cost of a replacement computer!
Tiger Prior - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 1,844
