주요 콘텐츠로 건너뛰기
Toshiba Chromebook CB35-A3120 Speakers Replacement
필요한 것
  1. Toshiba Chromebook CB35-A3120 Speakers Replacement, Speakers: 1 단계, 이미지 1/2 Toshiba Chromebook CB35-A3120 Speakers Replacement, Speakers: 1 단계, 이미지 2/2
    • Using a Y1 screw driver head remove all ten .9mm screws from the back cover
    • Set the screws aside in preparation for reassembly
  2. Toshiba Chromebook CB35-A3120 Speakers Replacement: 2 단계, 이미지 1/2 Toshiba Chromebook CB35-A3120 Speakers Replacement: 2 단계, 이미지 2/2
    • Remove the back cover by placing a prying tool in the SD slot and popping the clips out of place.
  3. Toshiba Chromebook CB35-A3120 Speakers Replacement: 3 단계, 이미지 1/3 Toshiba Chromebook CB35-A3120 Speakers Replacement: 3 단계, 이미지 2/3 Toshiba Chromebook CB35-A3120 Speakers Replacement: 3 단계, 이미지 3/3
    • Unscrew the battery by using a J1 screw driver head, and place the four .7mm screws off to the side
    • Using a pry tool, pop the battery connector out of place and gently lift the battery upward.
  4. Toshiba Chromebook CB35-A3120 Speakers Replacement: 4 단계, 이미지 1/3 Toshiba Chromebook CB35-A3120 Speakers Replacement: 4 단계, 이미지 2/3 Toshiba Chromebook CB35-A3120 Speakers Replacement: 4 단계, 이미지 3/3
    • Remove the right side speaker by popping it out of place with your finger
    • Follow the speaker wire along the clips underneath the battery until you reach the left hand speaker
  5. Toshiba Chromebook CB35-A3120 Speakers Replacement: 5 단계, 이미지 1/2 Toshiba Chromebook CB35-A3120 Speakers Replacement: 5 단계, 이미지 2/2
    • Unplug the connector wiring the speaker to the mother board.
    • Pop the speaker out of the computer, similar to the method used in the previous step.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jayce Houghton
회원 가입일: 02/15/17
176 평판
안내서 1개 작성함
USF Tampa, Team 15-6, Remmell Spring 2017 USF Tampa, Team 15-6, Remmell Spring 2017 회원
USFT-REMMELL-S17S15G6
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 13
전체 시간: 745
