주요 콘텐츠로 건너뛰기
Toshiba Dynabook AX 53D Hard Drive Replacement
필요한 것
  1. Toshiba Dynabook AX 53D Hard Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Push apart the two spring loaded plastic tabs labeled #1 and #2.
    • Make sure to unplug any external power sources before working on the computer.
  2. Toshiba Dynabook AX 53D Hard Drive Replacement: 2 단계, 이미지 1개 중 1개
    • The battery is now easily removed by pulling up from the notched tab on the inside edge.
  3. Toshiba Dynabook AX 53D Hard Drive Replacement, Hard Drive: 3 단계, 이미지 1개 중 1개
    • Start by using the #J1 screw bit to unscrew the the two 4.6 mm hard drive bay screws located on the underside of the laptop. They are located next to the Windows license sticker.
  4. Toshiba Dynabook AX 53D Hard Drive Replacement: 4 단계, 이미지 2개 중 1개 Toshiba Dynabook AX 53D Hard Drive Replacement: 4 단계, 이미지 2개 중 2개
    • Gently pull horizontally on the clear plastic tag to unplug the hard drive.
    • Make sure not to touch the circuit board or connectors on the drive as that may damage them.
  5. Toshiba Dynabook AX 53D Hard Drive Replacement: 5 단계, 이미지 1개 중 1개
    • The drive can now be removed from the metal drive retainer by unscrewing the four exposed 4.1 mm #J1 screws on either side of the drive.
  6. Toshiba Dynabook AX 53D Hard Drive Replacement: 6 단계, 이미지 1개 중 1개
    • The secondary hard drive can be removed following the same process on the right drive bay.
결론
작성자
2다른 기여자 명과 함께
Christopher
회원 가입일: 03/20/17
525 평판
안내서 5개를 작성함
UMass Dartmouth, Team S2-G7, Isaacson Spring 2017 UMass Dartmouth, Team S2-G7, Isaacson Spring 2017 회원
UMASSD-ISAACSON-S17S2G7
3 회원들
안내서 15개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 20
전체 시간: 1,241
