주요 콘텐츠로 건너뛰기
Toshiba Dynabook AX 53D Touchpad Replacement
필요한 것
  1. Toshiba Dynabook AX 53D Touchpad Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Push apart the two spring loaded plastic tabs labeled #1 and #2.
    • Make sure to unplug any external power sources before working on the computer.
  2. Toshiba Dynabook AX 53D Touchpad Replacement: 2 단계, 이미지 1개 중 1개
    • The battery is now easily removed by pulling up from the notched tab on the inside edge.
  3. Toshiba Dynabook AX 53D Touchpad Replacement, Keyboard: 3 단계, 이미지 1개 중 1개
    • Using the #J1 bit, remove the 17 recessed 7.3 mm B6 screws from the underside of laptop and the 3.1 mm #J0 F3 screw inside the battery compartment.
  4. Toshiba Dynabook AX 53D Touchpad Replacement: 4 단계, 이미지 2개 중 1개 Toshiba Dynabook AX 53D Touchpad Replacement: 4 단계, 이미지 2개 중 2개
    • Run the blue plastic opening tool underneath the media bezel and gently pry from the front panel.
  5. Toshiba Dynabook AX 53D Touchpad Replacement: 5 단계, 이미지 1개 중 1개
    • Using the #J0 bit, remove the two 3.1 mm screws securing the top of the keyboard.
  6. Toshiba Dynabook AX 53D Touchpad Replacement: 6 단계, 이미지 2개 중 1개 Toshiba Dynabook AX 53D Touchpad Replacement: 6 단계, 이미지 2개 중 2개
    • Pop out the black plastic tab on either side of the ribbon cable. Holding the cable on each side, detach from laptop.
  7. Toshiba Dynabook AX 53D Touchpad Replacement, Touchpad: 7 단계, 이미지 2개 중 1개 Toshiba Dynabook AX 53D Touchpad Replacement, Touchpad: 7 단계, 이미지 2개 중 2개
    • Detach the white plastic end of the braided LCD cable.
  8. Toshiba Dynabook AX 53D Touchpad Replacement: 8 단계, 이미지 2개 중 1개 Toshiba Dynabook AX 53D Touchpad Replacement: 8 단계, 이미지 2개 중 2개
    • Using the flat metal spatula tool, detach the thin white and black wires from their pop connectors.
  9. Toshiba Dynabook AX 53D Touchpad Replacement: 9 단계, 이미지 3개 중 1개 Toshiba Dynabook AX 53D Touchpad Replacement: 9 단계, 이미지 3개 중 2개 Toshiba Dynabook AX 53D Touchpad Replacement: 9 단계, 이미지 3개 중 3개
    • Using the #J1 Phillips Screwdriver, remove the four 7.6 mm screws that secure the monitor to rest of laptop.
    • The monitor can now be gently removed by lifting upwards.
  10. Toshiba Dynabook AX 53D Touchpad Replacement: 10 단계, 이미지 1개 중 1개
    • Run the plastic opening tool along the crease between the top touchpad bezel and bottom section of laptop.
  11. Toshiba Dynabook AX 53D Touchpad Replacement: 11 단계, 이미지 2개 중 1개 Toshiba Dynabook AX 53D Touchpad Replacement: 11 단계, 이미지 2개 중 2개
    • Gently detach the touchpad bezel.
    • The ribbon cable may break if removed roughly.
    • Gently remove the white ribbon cable.
  12. Toshiba Dynabook AX 53D Touchpad Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the six 3.7 mm #J1 screws holding the touchpad in place.
  13. Toshiba Dynabook AX 53D Touchpad Replacement: 13 단계, 이미지 1개 중 1개
    • Gently pull the ribbon cable to disconnect it from the touchpad.
  14. Toshiba Dynabook AX 53D Touchpad Replacement: 14 단계, 이미지 1개 중 1개
    • Carefully pry up the touchpad with a plastic opening tool.
  15. Toshiba Dynabook AX 53D Touchpad Replacement: 15 단계, 이미지 1개 중 1개
    • The touchpad has been removed.
결론
작성자
3다른 기여자 명과 함께
Christopher
회원 가입일: 03/20/17
525 평판
안내서 5개를 작성함
UMass Dartmouth, Team S2-G7, Isaacson Spring 2017 UMass Dartmouth, Team S2-G7, Isaacson Spring 2017 회원
UMASSD-ISAACSON-S17S2G7
3 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 23
전체 시간: 622
