주요 콘텐츠로 건너뛰기
Toshiba Dynabook T552-58G Hard Drive Replacement
필요한 것
  1. Toshiba Dynabook T552-58G Hard Drive Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
    • Turn the Toshiba Dynabook T552-58G so that the back panel is facing you.
  2. Toshiba Dynabook T552-58G Hard Drive Replacement: 2 단계, 이미지 2개 중 1개 Toshiba Dynabook T552-58G Hard Drive Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the 10 screws located on the back panel of the Toshiba Dynabook T552-58G using a PH 0 screwdriver.
    • Each screw will be 5.3 mm long.
  3. Toshiba Dynabook T552-58G Hard Drive Replacement: 3 단계, 이미지 3개 중 1개 Toshiba Dynabook T552-58G Hard Drive Replacement: 3 단계, 이미지 3개 중 2개 Toshiba Dynabook T552-58G Hard Drive Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the black screw using the J0 screwdriver. This is located by the top right foot of the device.
    • This will allow removal of the hard drive cover.
    • This screw will not come out of the hard drive cover.
  4. Toshiba Dynabook T552-58G Hard Drive Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the single screw located below the hard drive using the J0 screwdriver. This screw is 5.3 mm long.
  5. Toshiba Dynabook T552-58G Hard Drive Replacement: 5 단계, 이미지 3개 중 1개 Toshiba Dynabook T552-58G Hard Drive Replacement: 5 단계, 이미지 3개 중 2개 Toshiba Dynabook T552-58G Hard Drive Replacement: 5 단계, 이미지 3개 중 3개
    • Remove two screws located diagonally from the bottom-left screw of the hard drive using a J0 screwdriver. The screw closest to the hard drive is 5.2 mm long and the screw farther away is 4.2 mm long.
    • Remove the screw located diagonally from the top right screw of the hard drive using a J0 screwdriver. This screw is 5.2 mm long.
  6. Toshiba Dynabook T552-58G Hard Drive Replacement: 6 단계, 이미지 3개 중 1개 Toshiba Dynabook T552-58G Hard Drive Replacement: 6 단계, 이미지 3개 중 2개 Toshiba Dynabook T552-58G Hard Drive Replacement: 6 단계, 이미지 3개 중 3개
    • Slowly lift the back panel away from the computer.
    • There should be some resistance.
    • Once lifted, carefully remove the back panel.
  7. Toshiba Dynabook T552-58G Hard Drive Replacement, Hard Drive: 7 단계, 이미지 1개 중 1개
    • The hard drive is located in the under the L-shaped panel on the back of the computer.
  8. Toshiba Dynabook T552-58G Hard Drive Replacement: 8 단계, 이미지 1개 중 1개
    • Carefully push the hard drive to the left
  9. Toshiba Dynabook T552-58G Hard Drive Replacement: 9 단계, 이미지 1개 중 1개
    • Gently lift the hard drive using your fingers.
결론
작성자
2다른 기여자 명과 함께
Laney Pilkington
회원 가입일: 01/31/19
332 평판
안내서 2개를 작성함
댓글 한 개
Está em inglês deveria ter como traduzir aqui dentro da plataforma
Standley Richande - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 30
전체 시간: 751
