주요 콘텐츠로 건너뛰기
Toshiba Dynabook T552-58G Space Bar Replacement
  1. Toshiba Dynabook T552-58G Space Bar Replacement, Space Bar: 1 단계, 이미지 1/1
    • The space bar is located on the bottom of the keyboard.
  2. Toshiba Dynabook T552-58G Space Bar Replacement: 2 단계, 이미지 1/2 Toshiba Dynabook T552-58G Space Bar Replacement: 2 단계, 이미지 2/2
    • Gently pry the broken space bar up with from the back with your finger.
  3. Toshiba Dynabook T552-58G Space Bar Replacement: 3 단계, 이미지 1/1
    • You should now see the key retainer.
    • Do not remove anything else because this is crucial for replacing the key.
  4. Toshiba Dynabook T552-58G Space Bar Replacement: 4 단계, 이미지 1/3 Toshiba Dynabook T552-58G Space Bar Replacement: 4 단계, 이미지 2/3 Toshiba Dynabook T552-58G Space Bar Replacement: 4 단계, 이미지 3/3
    • Gently lift up the bottom metal prongs.
    • Insert the two ends of the prong into the small metal loops located at the top of the key pad.
    • Gently press the key down until you hear a click.
결승점
Lilly Pilkington
회원 가입일: 01/31/19
235 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 10
전체 시간: 471
