주요 콘텐츠로 건너뛰기
Toshiba Encore 2 WT10-A Battery Replacement
필요한 것
  1. Toshiba Encore 2 WT10-A Battery Replacement, Battery: 1 단계, 이미지 1/3 Toshiba Encore 2 WT10-A Battery Replacement, Battery: 1 단계, 이미지 2/3 Toshiba Encore 2 WT10-A Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Start by holding your Toshiba tablet faced up.
    • Flip the tablet from left to right so that you are able to see the back of the tablet.
    • Hold tablet and be ready to continue onto the next steps.
  2. Toshiba Encore 2 WT10-A Battery Replacement: 2 단계, 이미지 1/3 Toshiba Encore 2 WT10-A Battery Replacement: 2 단계, 이미지 2/3 Toshiba Encore 2 WT10-A Battery Replacement: 2 단계, 이미지 3/3
    • Insert a plastic opening tool in the back case of the tablet to free the clips.
    • Begin to pull the tool up slightly and work your way around the tablet to free all the clips.
    • Using a metal opening tool as shown in the photos has the potential to damage your device.
  3. Toshiba Encore 2 WT10-A Battery Replacement: 3 단계, 이미지 1/3 Toshiba Encore 2 WT10-A Battery Replacement: 3 단계, 이미지 2/3 Toshiba Encore 2 WT10-A Battery Replacement: 3 단계, 이미지 3/3
    • Hold back lid with your right hand and keep lifting to remove the back lid.
    • Pull the back lid from right to left and top to bottom.
    • Once you disconnect the back lid, place lid aside.
  4. Toshiba Encore 2 WT10-A Battery Replacement: 4 단계, 이미지 1/2 Toshiba Encore 2 WT10-A Battery Replacement: 4 단계, 이미지 2/2
    • Use plastic spudger to remove the attached battery wires by pushing the plastic wire holder from right to left on top and bottom part of plastic holder.
  5. Toshiba Encore 2 WT10-A Battery Replacement: 5 단계, 이미지 1/3 Toshiba Encore 2 WT10-A Battery Replacement: 5 단계, 이미지 2/3 Toshiba Encore 2 WT10-A Battery Replacement: 5 단계, 이미지 3/3
    • Start by using your left hand on the top left corner on the battery.
    • Then, begin to lift and work your way around the battery.
  6. Toshiba Encore 2 WT10-A Battery Replacement: 6 단계, 이미지 1/2 Toshiba Encore 2 WT10-A Battery Replacement: 6 단계, 이미지 2/2
    • Remove the battery from the compartment.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Eileen Morales
회원 가입일: 04/08/19
151 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 17
전체 시간: 1,711
