주요 콘텐츠로 건너뛰기
Toshiba Encore 2 WT8-B Battery Replacement
필요한 것
  1. Toshiba Encore 2 WT8-B Battery Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Encore 2 WT8-B Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Lay the tablet face down.
    • Use the Opening pick at the back of the tablet to free the clips. Begin to pull the tool up slightly and work your way around the tablet to free all the clips.
    • Remove the back panel from the tablet.
    • Using a metal prying tool could damage the device.
  2. Toshiba Encore 2 WT8-B Battery Replacement: 2 단계, 이미지 1/3 Toshiba Encore 2 WT8-B Battery Replacement: 2 단계, 이미지 2/3 Toshiba Encore 2 WT8-B Battery Replacement: 2 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use a pair of fine tweezers or your fingers to flip up the small retaining flap. Then, you can safely pull the ribbon cable out.
    • Repeat on both ends.
    • Make sure to pull out the hinged flap of the ribbon and not the connector.
  3. Toshiba Encore 2 WT8-B Battery Replacement: 3 단계, 이미지 1/1
    • Remove the attached battery wires by pushing the plastic wire holder from right to left on top and bottom part of plastic holder.
    • Be sure to be very gentle when prying colored wires from motherboard to ensure that there is no damage.
  4. Toshiba Encore 2 WT8-B Battery Replacement: 4 단계, 이미지 1/2 Toshiba Encore 2 WT8-B Battery Replacement: 4 단계, 이미지 2/2
    • Use the Phillips #00 screwdriver to remove the seven battery screws connecting the battery to the unit.
  5. Toshiba Encore 2 WT8-B Battery Replacement: 5 단계, 이미지 1/2 Toshiba Encore 2 WT8-B Battery Replacement: 5 단계, 이미지 2/2
    • Remove the battery out of the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Manfred Rebello
회원 가입일: 02/13/20
145 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 10
30일 전: 22
전체 시간: 1,027
