주요 콘텐츠로 건너뛰기
Toshiba Encore Mini Battery Replacement
필요한 것
  1. Toshiba Encore Mini Battery Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Encore Mini Battery Replacement, Battery: 1 단계, 이미지 2/2
    • To replace the battery, the rear cover must first be removed.
    • Using the flat end of the spudger, gently pry open the back case from the rest of the device.
    • It may be easier to start along one of the long edges and carefully work your way toward the corner, then along the short edge.
  2. Toshiba Encore Mini Battery Replacement: 2 단계, 이미지 1/1
    • Remove the rear cover and set it aside.
  3. Toshiba Encore Mini Battery Replacement: 3 단계, 이미지 1/1
    • Carefully remove the electrical tape that holds the battery in place.
  4. Toshiba Encore Mini Battery Replacement: 4 단계, 이미지 1/2 Toshiba Encore Mini Battery Replacement: 4 단계, 이미지 2/2
    • Using needle-nose tweezers, gently push the large white wire connector (connected to the black, red and blue wires) out of its housing.
  5. Toshiba Encore Mini Battery Replacement: 5 단계, 이미지 1/1
    • Gently lift the battery out of the device.
    • Be careful not to pull on the connecting wires.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Erica Jouglard
회원 가입일: 07/08/15
263 평판
안내서 1개 작성함
UW Tacoma, Team 1-3, Liner SU 2015 UW Tacoma, Team 1-3, Liner SU 2015 회원
UWT-LINER-SU15S1G3
4 회원들
안내서 6개 작성하였습니다
댓글 2개
Be sure to remove any SD cards you have first.
ecw0647 - 답글
But where do i buy the battery?
sissyhana - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 7
전체 시간: 4,009
