주요 콘텐츠로 건너뛰기
Toshiba Encore Mini Speakers Replacement
필요한 것
  1. Toshiba Encore Mini Speakers Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Encore Mini Speakers Replacement, Battery: 1 단계, 이미지 2/2
    • To replace the battery, the rear cover must first be removed.
    • Using the flat end of the spudger, gently pry open the back case from the rest of the device.
    • It may be easier to start along one of the long edges and carefully work your way toward the corner, then along the short edge.
  2. Toshiba Encore Mini Speakers Replacement: 2 단계, 이미지 1/1
    • Remove the rear cover and set it aside.
  3. Toshiba Encore Mini Speakers Replacement: 3 단계, 이미지 1/1
    • Carefully remove the electrical tape that holds the battery in place.
  4. Toshiba Encore Mini Speakers Replacement: 4 단계, 이미지 1/2 Toshiba Encore Mini Speakers Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using needle-nose tweezers, gently push the large white wire connector (connected to the black, red and blue wires) out of its housing.
  5. Toshiba Encore Mini Speakers Replacement: 5 단계, 이미지 1/1
    • Gently lift the battery out of the device.
    • Be careful not to pull on the connecting wires.
  6. Toshiba Encore Mini Speakers Replacement, Speakers: 6 단계, 이미지 1/1
    • Use the spudger to pull the speaker wire plug from its socket.
  7. Toshiba Encore Mini Speakers Replacement: 7 단계, 이미지 1/1
    • Carefully use the metal spudger to remove the speaker from the frame of the phone.
    • The speaker is attached with some double-sided adhesive and may be difficult to remove.
결론
Khaled Alsaghayer
회원 가입일: 03/04/17
101 평판
안내서 1개 작성함
IUPUI, Team S5-G5, Wilson Spring 2017 IUPUI, Team S5-G5, Wilson Spring 2017 회원
IUPUI-WILSON-S17S5G5
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 6
전체 시간: 154
