주요 콘텐츠로 건너뛰기
Toshiba Encore WT8-A Tablet Camera Replacement
필요한 것
  1. Toshiba Encore WT8-A Tablet  Camera Replacement, Motherboard: 1 단계, 이미지 1/1
    • Remove the 4 – 4.5 mm screws from the motherboard assembly.
  2. Toshiba Encore WT8-A Tablet  Camera Replacement: 2 단계, 이미지 1/1
    • Remove the 2 – 3.5 mm screws from the motherboard assembly.
  3. Toshiba Encore WT8-A Tablet  Camera Replacement: 3 단계, 이미지 1/1
    • The motherboard should come free at this point.
  4. Toshiba Encore WT8-A Tablet  Camera Replacement, Camera: 4 단계, 이미지 1/1
    • Use small plastic opening tool for the following steps.
  5. Toshiba Encore WT8-A Tablet  Camera Replacement: 5 단계, 이미지 1/2 Toshiba Encore WT8-A Tablet  Camera Replacement: 5 단계, 이미지 2/2
    • Use small plastic opening tool to pry rear facing camera flat top connector from motherboard.
  6. Toshiba Encore WT8-A Tablet  Camera Replacement: 6 단계, 이미지 1/1
    • The rear facing camera should come free at this point.
  7. Toshiba Encore WT8-A Tablet  Camera Replacement: 7 단계, 이미지 1/1
    • Use small plastic opening tool to pry front facing camera flat top connector from the motherboard
  8. Toshiba Encore WT8-A Tablet  Camera Replacement: 8 단계, 이미지 1/2 Toshiba Encore WT8-A Tablet  Camera Replacement: 8 단계, 이미지 2/2
    • The front facing camera should come free at this point.
결론
Melanie Mestre
회원 가입일: 09/20/16
116 평판
안내서 1개 작성함
USF Tampa, Team 17-4, Blackwell Fall 2016 USF Tampa, Team 17-4, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S17G4
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 12
전체 시간: 693
