주요 콘텐츠로 건너뛰기
Toshiba Encore WT8-A Tablet Audio Jack Replacement
필요한 것
  1. Toshiba Encore WT8-A Tablet Audio Jack Replacement, Battery: 1 단계, 이미지 1/1
    • Use the metal spudger to create a gap between the back cover and the device.
    • Be gentle when using the metal spudger so that the casing is not damaged.
  2. Toshiba Encore WT8-A Tablet Audio Jack Replacement: 2 단계, 이미지 1/2 Toshiba Encore WT8-A Tablet Audio Jack Replacement: 2 단계, 이미지 2/2
    • Use the nylon spudger to completely separate the back of the device.
    • Take the nylon spudger around the outside of the device cover until it comes free.
  3. Toshiba Encore WT8-A Tablet Audio Jack Replacement: 3 단계, 이미지 1/2 Toshiba Encore WT8-A Tablet Audio Jack Replacement: 3 단계, 이미지 2/2
    • Use the Phillips head PH0 to remove the 7 battery screws.
    • The 5 side screws measure 3.5mm.
    • The 2 top and bottom screws measure 4.5 mm.
  4. Toshiba Encore WT8-A Tablet Audio Jack Replacement: 4 단계, 이미지 1/2 Toshiba Encore WT8-A Tablet Audio Jack Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • To disconnect the cable, use the fine tweezers to flip up the small retaining flap. Then, you can safely pull the ribbon cable out.
    • Be sure you are prying up on the hinged retaining flap, not the connector itself.
    • The zero insertion force (ZIF) connector is used to secure delicate ribbon cables, such as this trackpad cable.
  5. Toshiba Encore WT8-A Tablet Audio Jack Replacement: 5 단계, 이미지 1/1
    • Remove the colored power cable from its connector.
    • To disconnect it safely, use the pointed tip of a spudger to carefully push on each side of the connector.
    • Alternating from one side to the other, gently “walk” the connector out of its socket.
    • Be sure to be very gentle when prying colored wires from motherboard to ensure that there is no damage.
  6. Toshiba Encore WT8-A Tablet Audio Jack Replacement: 6 단계, 이미지 1/1
    • Battery will lift out of the device.
  7. Toshiba Encore WT8-A Tablet Audio Jack Replacement, Motherboard: 7 단계, 이미지 1/1
    • Remove the 4 – 4.5 mm screws from the motherboard assembly.
  8. Toshiba Encore WT8-A Tablet Audio Jack Replacement: 8 단계, 이미지 1/1
    • Remove the 2 – 3.5 mm screws from the motherboard assembly.
  9. Toshiba Encore WT8-A Tablet Audio Jack Replacement: 9 단계, 이미지 1/1
    • The motherboard should come free at this point.
  10. Toshiba Encore WT8-A Tablet Audio Jack Replacement, Audio Jack: 10 단계, 이미지 1/1
    • Prepare soldering iron to heat the connections to the motherboard.
    • Soldering irons are very hot, use caution as not to burn yourself, or other parts of the motherboard.
  11. Toshiba Encore WT8-A Tablet Audio Jack Replacement: 11 단계, 이미지 1/3 Toshiba Encore WT8-A Tablet Audio Jack Replacement: 11 단계, 이미지 2/3 Toshiba Encore WT8-A Tablet Audio Jack Replacement: 11 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use the soldering iron to melt the metal connection from the motherboard to the audio jack.
    • Use the fine pointed tweezers to pull the audio jack away from the motherboard.
    • Do not touch the audio jack or surrounding area with your hands, melted metal is very hot.
    • The solder cools quickly so you will have to be quick and precise.
  12. Toshiba Encore WT8-A Tablet Audio Jack Replacement: 12 단계, 이미지 1/1
    • Upon acquiring a new audio jack, use the soldering iron to solder the six connection ports into the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Zack Smith
회원 가입일: 09/20/16
119 평판
안내서 1개 작성함
USF Tampa, Team 17-4, Blackwell Fall 2016 USF Tampa, Team 17-4, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S17G4
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 554
