주요 콘텐츠로 건너뛰기
소개
The fix, I place a thin alloy shim between the existing heatsink & chip, with a good quality thermal paste, I always use artic silver 5(never lets you down)
부품
지정된 부품이 없습니다.
  1. This is a complete top half strip down to fix (takes me less than 30 minutes)
    • This is a complete top half strip down to fix (takes me less than 30 minutes)
  2. this is the culprit, as you can see the shim can easily overheat & go concave lifting off the chip.
    • this is the culprit, as you can see the shim can easily overheat & go concave lifting off the chip.
  3. cut  a  thin piece of alloy to the same size as the existing shim, i used an old alloy door push plate(easy to cut) & is the ideal thickness
    • cut a thin piece of alloy to the same size as the existing shim, i used an old alloy door push plate(easy to cut) & is the ideal thickness
  4. PC 노트북 배터리
    큰 전력 향상을 위한 손쉬운 수리.
    지금 장보기
    PC 노트북 배터리
    큰 전력 향상을 위한 손쉬운 수리.
    지금 장보기
  5. Thoroughly clean the chip with pure alcohol, then apply an even spread of good quality thermal paste(Arctic silver 5) will never let you down
    • Thoroughly clean the chip with pure alcohol, then apply an even spread of good quality thermal paste(Arctic silver 5) will never let you down
  6. THen apply more thermal paste to the top of the shim
    • THen apply more thermal paste to the top of the shim
  7. The new alloy shim is under the existing thin shim. I've done more than 20 of these repairs & had 100% success rate I always do the same to the CPU (might as well your already in there).,
    • The new alloy shim is under the existing thin shim. I've done more than 20 of these repairs & had 100% success rate I always do the same to the CPU (might as well your already in there).,
  8. This is the CPU with the new alloy shim fitted.
    • This is the CPU with the new alloy shim fitted.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Terry Sim
회원 가입일: 2011년 02월 12일
209 평판
안내서 1개 작성함
Pros: Very good hi-res pictures, well explained.
Cons: The disassembly instructions are missing
Nicola Nascimento - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 1,802
