주요 콘텐츠로 건너뛰기
Toshiba Excite 10 AT300 Front-Facing Camera Replacement
필요한 것
  1. Toshiba Excite 10 AT300 Front-Facing Camera Replacement, Remove SD Card: 1 단계, 이미지 1/1
    • Remove the SD card from the SD card slot.
  2. Toshiba Excite 10 AT300 Front-Facing Camera Replacement, Open the Tablet: 2 단계, 이미지 1/3 Toshiba Excite 10 AT300 Front-Facing Camera Replacement, Open the Tablet: 2 단계, 이미지 2/3 Toshiba Excite 10 AT300 Front-Facing Camera Replacement, Open the Tablet: 2 단계, 이미지 3/3
    • Use the opening tool to separate the front and rear panels by slipping the tool underneath the screen edge and sliding it around the entire device.
    • Make sure you unclip all of the clips on the back panel, or pulling it off will be difficult and may damage the tablet.
  3. Toshiba Excite 10 AT300 Front-Facing Camera Replacement, Disconnect Speaker Wires: 3 단계, 이미지 1/3 Toshiba Excite 10 AT300 Front-Facing Camera Replacement, Disconnect Speaker Wires: 3 단계, 이미지 2/3 Toshiba Excite 10 AT300 Front-Facing Camera Replacement, Disconnect Speaker Wires: 3 단계, 이미지 3/3
    • Remove the speaker cable from its socket by gripping both sides of the white connector piece with tweezers and pulling straight out.
    • Be careful not to rip the wires out of the white connector piece.
  4. Toshiba Excite 10 AT300 Front-Facing Camera Replacement, Remove Screws: 4 단계, 이미지 1/2 Toshiba Excite 10 AT300 Front-Facing Camera Replacement, Remove Screws: 4 단계, 이미지 2/2
    • Using a #00 Phillips screwdriver, remove the following screws:
    • Five 3mm Phillips #00 screws
  5. Toshiba Excite 10 AT300 Front-Facing Camera Replacement, Remove Battery Cable: 5 단계, 이미지 1/3 Toshiba Excite 10 AT300 Front-Facing Camera Replacement, Remove Battery Cable: 5 단계, 이미지 2/3 Toshiba Excite 10 AT300 Front-Facing Camera Replacement, Remove Battery Cable: 5 단계, 이미지 3/3
    • Gently lift the battery, pulling away from the tab holding it in place at the bottom.
    • While holding the battery up, use a pair of tweezers to remove the battery cable from its connector.
  6. Toshiba Excite 10 AT300 Front-Facing Camera Replacement, Remove the foil wire: 6 단계, 이미지 1/2 Toshiba Excite 10 AT300 Front-Facing Camera Replacement, Remove the foil wire: 6 단계, 이미지 2/2
    • Using tweezers, pull the copper foil up from the back of the camera. It should peel up easily.
    • Warning: Be careful to avoid ripping the foil.
  7. Toshiba Excite 10 AT300 Front-Facing Camera Replacement, Remove the ribbon cable: 7 단계, 이미지 1/1
    • Carefully remove the ribbon cable from the housing by pulling gently upwards on the sides of the cable housing. The cable should come straight up off of its housing.
결론
Gus Holz
회원 가입일: 10/09/14
297 평판
안내서 2개 작성하였습니다
Cal Poly, Team 14-26, Maness Fall 2014 Cal Poly, Team 14-26, Maness Fall 2014 회원
CPSU-MANESS-F14S14G26
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 6
전체 시간: 662
