주요 콘텐츠로 건너뛰기
Toshiba Excite 10 AT300 Speaker Replacement
필요한 것
  1. Toshiba Excite 10 AT300 Speaker Replacement, Remove SD Card: 1 단계, 이미지 1/1
    • Remove the SD card from the SD card slot.
  2. Toshiba Excite 10 AT300 Speaker Replacement, Open the Tablet: 2 단계, 이미지 1/3 Toshiba Excite 10 AT300 Speaker Replacement, Open the Tablet: 2 단계, 이미지 2/3 Toshiba Excite 10 AT300 Speaker Replacement, Open the Tablet: 2 단계, 이미지 3/3
    • Use the opening tool to separate the front and rear panels by slipping the tool underneath the screen edge and sliding it around the entire device.
    • Make sure you unclip all of the clips on the back panel, or pulling it off will be difficult and may damage the tablet.
  3. Toshiba Excite 10 AT300 Speaker Replacement, Disconnect Speaker Wires: 3 단계, 이미지 1/3 Toshiba Excite 10 AT300 Speaker Replacement, Disconnect Speaker Wires: 3 단계, 이미지 2/3 Toshiba Excite 10 AT300 Speaker Replacement, Disconnect Speaker Wires: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Remove the speaker cable from its socket by gripping both sides of the white connector piece with tweezers and pulling straight out.
    • Be careful not to rip the wires out of the white connector piece.
  4. Toshiba Excite 10 AT300 Speaker Replacement, Removing Tape: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Using either your hands or tweezers remove the 3 pieces of tape holding the speaker wires to the back panel.
  5. Toshiba Excite 10 AT300 Speaker Replacement, Unscrew Speakers: 5 단계, 이미지 1/1
    • Using a #00 Phillips screwdriver, remove the four 3mm #00 Phillips screws that hold the speakers in place.
    • Using your hands, remove the old speakers from back panel of tablet.
    • Place the new speakers where the old speakers were and in the same orientation.
결론
Andrew Gillis
회원 가입일: 10/09/14
564 평판
안내서 3개 작성하였습니다
Cal Poly, Team 14-26, Maness Fall 2014 Cal Poly, Team 14-26, Maness Fall 2014 회원
CPSU-MANESS-F14S14G26
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 922
