소개
This guide will show you how to replace the motherboard in your Toshiba Excite 7c tablet. Replacing the motherboard is a last resort to fix a malfunctioning device. Unless there is visible damage to the motherboard, your problem may be caused by something else. Before beginning the repair make sure you have exhausted other troubleshooting options.
필요한 것
Place an iFixit opening tool in the seam between the screen and back casing.
Apply pressure down all four sides to separate the back casing from the screen.
Place the tablet face down and carefully remove the back panel.
다른 한 분이 해당 안내서를 완성하였습니다.
