주요 콘텐츠로 건너뛰기
Toshiba HD-A2 Drive Belt Replacement
필요한 것
  1. Toshiba HD-A2 Drive Belt Replacement, Top Panel: 1 단계, 이미지 1/1
    • Remove the three 6mm Phillips head screws on the back of the DVD player with a Phillips #1 screwdriver.
  2. Toshiba HD-A2 Drive Belt Replacement: 2 단계, 이미지 1/2 Toshiba HD-A2 Drive Belt Replacement: 2 단계, 이미지 2/2
    • Remove the two 3mm Phillips screws on each side of the DVD player using the Phillips #1 screwdriver.
  3. Toshiba HD-A2 Drive Belt Replacement: 3 단계, 이미지 1/1
    • Using your hand, gently lift the black top panel and safely place it off to the side.
  4. Toshiba HD-A2 Drive Belt Replacement, Optical Drive: 4 단계, 이미지 1/3 Toshiba HD-A2 Drive Belt Replacement, Optical Drive: 4 단계, 이미지 2/3 Toshiba HD-A2 Drive Belt Replacement, Optical Drive: 4 단계, 이미지 3/3
    • Remove five 6mm Phillips screws with a Phillips #2 screwdriver.
    • The 2 screws on the right of the cartridge are better shown in the second and third photos.
  5. Toshiba HD-A2 Drive Belt Replacement: 5 단계, 이미지 1/2 Toshiba HD-A2 Drive Belt Replacement: 5 단계, 이미지 2/2
    • Remove the remaining four 6mm Phillips screws.
  6. Toshiba HD-A2 Drive Belt Replacement: 6 단계, 이미지 1/3 Toshiba HD-A2 Drive Belt Replacement: 6 단계, 이미지 2/3 Toshiba HD-A2 Drive Belt Replacement: 6 단계, 이미지 3/3
    • Using your fingers, gently remove the metal pieces on each side of the cartridge and carefully place them aside.
  7. Toshiba HD-A2 Drive Belt Replacement: 7 단계, 이미지 1/2 Toshiba HD-A2 Drive Belt Replacement: 7 단계, 이미지 2/2
    • Gently lift the cartridge. Remove two 4mm Phillips screws from the green circuit board.
  8. Toshiba HD-A2 Drive Belt Replacement: 8 단계, 이미지 1/1
    • Using your fingers, gently pull off the wires.
  9. Toshiba HD-A2 Drive Belt Replacement: 9 단계, 이미지 1/2 Toshiba HD-A2 Drive Belt Replacement: 9 단계, 이미지 2/2
    • Using your fingers, pull off the green circuit board from the cartridge and carefully place it down.
    • Be careful not to rip the tape attaching the green circuit boards together.
  10. Toshiba HD-A2 Drive Belt Replacement: 10 단계, 이미지 1/2 Toshiba HD-A2 Drive Belt Replacement: 10 단계, 이미지 2/2
    • Flip the cartridge over to the bare side with no stickers. Remove four 10mm Phillips screws from each corner.
  11. Toshiba HD-A2 Drive Belt Replacement: 11 단계, 이미지 1/2 Toshiba HD-A2 Drive Belt Replacement: 11 단계, 이미지 2/2
    • Using your hands, gently lift the lid and carefully place it aside.
  12. Toshiba HD-A2 Drive Belt Replacement: 12 단계, 이미지 1/3 Toshiba HD-A2 Drive Belt Replacement: 12 단계, 이미지 2/3 Toshiba HD-A2 Drive Belt Replacement: 12 단계, 이미지 3/3
    • Flip over the cartridge. Using your hands, gently lift the rest of the silver case.
  13. Toshiba HD-A2 Drive Belt Replacement, Drive Belt: 13 단계, 이미지 1/3 Toshiba HD-A2 Drive Belt Replacement, Drive Belt: 13 단계, 이미지 2/3 Toshiba HD-A2 Drive Belt Replacement, Drive Belt: 13 단계, 이미지 3/3
    • Slide out the disc tray. If it's stuck, turn the white gear to the right to release the tray.
  14. Toshiba HD-A2 Drive Belt Replacement: 14 단계, 이미지 1/1
    • The drive belt is the black rubber band.
  15. Toshiba HD-A2 Drive Belt Replacement: 15 단계, 이미지 1/2 Toshiba HD-A2 Drive Belt Replacement: 15 단계, 이미지 2/2
    • Using your fingers, gently remove the drive belt.
    • If you have difficulty using your fingers, use a prying tool.
결론
Nouriyah Saleh
회원 가입일: 10/22/18
800 평판
안내서 6개 작성하였습니다
UC Davis, Team S11-G1, Lore Fall 2018 UC Davis, Team S11-G1, Lore Fall 2018 회원
UCD-LORE-F18S11G1
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 12
전체 시간: 400
