주요 콘텐츠로 건너뛰기
Toshiba HD-A2 Optical Lens Replacement
필요한 것
  1. Toshiba HD-A2 Optical Lens Replacement, Top Panel: 1 단계, 이미지 1/1
    • Remove the three 6mm Phillips head screws on the back of the DVD player with a Phillips #1 screwdriver.
  2. Toshiba HD-A2 Optical Lens Replacement: 2 단계, 이미지 1/2 Toshiba HD-A2 Optical Lens Replacement: 2 단계, 이미지 2/2
    • Remove the two 3mm Phillips screws on each side of the DVD player using the Phillips #1 screwdriver.
  3. Toshiba HD-A2 Optical Lens Replacement: 3 단계, 이미지 1/1
    • Using your hand, gently lift the black top panel and safely place it off to the side.
  4. Toshiba HD-A2 Optical Lens Replacement, Optical Drive: 4 단계, 이미지 1/3 Toshiba HD-A2 Optical Lens Replacement, Optical Drive: 4 단계, 이미지 2/3 Toshiba HD-A2 Optical Lens Replacement, Optical Drive: 4 단계, 이미지 3/3
    • Remove five 6mm Phillips screws with a Phillips #2 screwdriver.
    • The 2 screws on the right of the cartridge are better shown in the second and third photos.
  5. Toshiba HD-A2 Optical Lens Replacement: 5 단계, 이미지 1/2 Toshiba HD-A2 Optical Lens Replacement: 5 단계, 이미지 2/2
    • Remove the remaining four 6mm Phillips screws.
  6. Toshiba HD-A2 Optical Lens Replacement: 6 단계, 이미지 1/3 Toshiba HD-A2 Optical Lens Replacement: 6 단계, 이미지 2/3 Toshiba HD-A2 Optical Lens Replacement: 6 단계, 이미지 3/3
    • Using your fingers, gently remove the metal pieces on each side of the cartridge and carefully place them aside.
  7. Toshiba HD-A2 Optical Lens Replacement: 7 단계, 이미지 1/2 Toshiba HD-A2 Optical Lens Replacement: 7 단계, 이미지 2/2
    • Gently lift the cartridge. Remove two 4mm Phillips screws from the green circuit board.
  8. Toshiba HD-A2 Optical Lens Replacement: 8 단계, 이미지 1/1
    • Using your fingers, gently pull off the wires.
  9. Toshiba HD-A2 Optical Lens Replacement: 9 단계, 이미지 1/2 Toshiba HD-A2 Optical Lens Replacement: 9 단계, 이미지 2/2
    • Using your fingers, pull off the green circuit board from the cartridge and carefully place it down.
    • Be careful not to rip the tape attaching the green circuit boards together.
  10. Toshiba HD-A2 Optical Lens Replacement: 10 단계, 이미지 1/2 Toshiba HD-A2 Optical Lens Replacement: 10 단계, 이미지 2/2
    • Flip the cartridge over to the bare side with no stickers. Remove four 10mm Phillips screws from each corner.
  11. Toshiba HD-A2 Optical Lens Replacement: 11 단계, 이미지 1/2 Toshiba HD-A2 Optical Lens Replacement: 11 단계, 이미지 2/2
    • Using your hands, gently lift the lid and carefully place it aside.
  12. Toshiba HD-A2 Optical Lens Replacement: 12 단계, 이미지 1/3 Toshiba HD-A2 Optical Lens Replacement: 12 단계, 이미지 2/3 Toshiba HD-A2 Optical Lens Replacement: 12 단계, 이미지 3/3
    • Flip over the cartridge. Using your hands, gently lift the rest of the silver case.
  13. Toshiba HD-A2 Optical Lens Replacement, Optical Lens: 13 단계, 이미지 1/1
    • The optical lens will be resting aside the small green circuit board.
  14. Toshiba HD-A2 Optical Lens Replacement: 14 단계, 이미지 1/2 Toshiba HD-A2 Optical Lens Replacement: 14 단계, 이미지 2/2
    • Using a prying tool, wedge the edge of the tool underneath the end of the optical lens closest to the green circuit board. Gently push down to pop off the optical lens.
결론
Nouriyah Saleh
회원 가입일: 10/22/18
800 평판
안내서 6개 작성하였습니다
UC Davis, Team S11-G1, Lore Fall 2018 UC Davis, Team S11-G1, Lore Fall 2018 회원
UCD-LORE-F18S11G1
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 14
전체 시간: 545
