주요 콘텐츠로 건너뛰기
Toshiba HD-A2 Power Button Replacement
필요한 것
  1. Toshiba HD-A2 Power Button Replacement, Power Button: 1 단계, 이미지 1/3 Toshiba HD-A2 Power Button Replacement, Power Button: 1 단계, 이미지 2/3 Toshiba HD-A2 Power Button Replacement, Power Button: 1 단계, 이미지 3/3
    • Using your hands, pop off the black console from each hinge surrounding the case.
    • There are a total of 7 hinges.
  2. Toshiba HD-A2 Power Button Replacement: 2 단계, 이미지 1/1
    • With the inside of the console facing up, the power button will be encased in clear plastic located on the right side of the console.
  3. Toshiba HD-A2 Power Button Replacement: 3 단계, 이미지 1/2 Toshiba HD-A2 Power Button Replacement: 3 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to remove the single screw holding the power button to the console.
    • After taking out the screw, the small piece of metal underneath will come loose. Carefully place this part aside.
  4. Toshiba HD-A2 Power Button Replacement: 4 단계, 이미지 1/1
    • Using your fingers, gently pull out the power button. You can push it from the outside to help loosen it from its hinges.
결론
Nouriyah Saleh
회원 가입일: 10/22/18
800 평판
안내서 6개 작성하였습니다
UC Davis, Team S11-G1, Lore Fall 2018 UC Davis, Team S11-G1, Lore Fall 2018 회원
UCD-LORE-F18S11G1
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 143
