주요 콘텐츠로 건너뛰기
Toshiba NB205 N330PK Battery Replacement
필요한 것
  1. Toshiba NB205 N330PK Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • To release the battery, first slide the switch to the right.
  2. Toshiba NB205 N330PK Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Use your right hand to slide the second release switch to the right to unlock the battery.
    • Simultaneously, use your left hand to pull the battery towards the top of the netbook.
  3. Toshiba NB205 N330PK Battery Replacement: 3 단계, 이미지 2개 중 1개 Toshiba NB205 N330PK Battery Replacement: 3 단계, 이미지 2개 중 2개
    • With a soft or medium bristle brush, gently remove debris from the battery's contacts.
    • Similarly, remove debris from the matching contacts on the netbook itself.
    • Ensure hands and brush are dry to prevent personal injury from electric shock.
  4. Toshiba NB205 N330PK Battery Replacement: 4 단계, 이미지 2개 중 1개 Toshiba NB205 N330PK Battery Replacement: 4 단계, 이미지 2개 중 2개
    • To reconnect the battery, align these hooks with the designated holes on the netbook.
    • Firmly press the battery back into its original position. A clicking noise should be heard as the switch (bottom switch in photo's orientation) automatically moves.
  5. Toshiba NB205 N330PK Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Move the switch to the left position to secure the battery and lock it in place. This ensure a strong battery connection and prevents battery from falling out.
결론
Follow this guide from beginning to end for battery removal, replacement, and cleaning.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Mason McCaskill
회원 가입일: 10/18/13
1,021 평판
안내서 9개를 작성함
Clemson, Team 14-2, Benson Fall 2013 Clemson, Team 14-2, Benson Fall 2013 회원
CLEM-BENSON-F13S14G2
3 회원들
안내서 27개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 863
