주요 콘텐츠로 건너뛰기
Toshiba NB205 N330PK RAM Replacement
필요한 것
  1. Toshiba NB205 N330PK RAM Replacement, RAM: 1 단계, 이미지 1/2 Toshiba NB205 N330PK RAM Replacement, RAM: 1 단계, 이미지 2/2
    • Use a bit driver and a Phillips #0 bit to remove the one 5 mm retaining screw.
    • Lift the panel up and out of the way.
  2. Toshiba NB205 N330PK RAM Replacement: 2 단계, 이미지 1/3 Toshiba NB205 N330PK RAM Replacement: 2 단계, 이미지 2/3 Toshiba NB205 N330PK RAM Replacement: 2 단계, 이미지 3/3
    • The RAM chip is secured by two retaining arms that run parallel with the chip. Gently pull these arms in opposite directions off of the chip.
    • After the retainer arms are free, push the chip towards the top of the netbook. This will free the chip for removal.
  3. Toshiba NB205 N330PK RAM Replacement: 3 단계, 이미지 1/2 Toshiba NB205 N330PK RAM Replacement: 3 단계, 이미지 2/2
    • Push the replacement RAM into the original position.
    • Reattach both securing arms onto the sides of the RAM chip.
  4. Toshiba NB205 N330PK RAM Replacement: 4 단계, 이미지 1/2 Toshiba NB205 N330PK RAM Replacement: 4 단계, 이미지 2/2
    • Place the panel back into the securing slots and let it rest in its original position.
    • With the bit driver and Phillips #0 bit, secure the panel down with one screw.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Mason McCaskill
회원 가입일: 10/18/13
1,000 평판
안내서 9개 작성하였습니다
Clemson, Team 14-2, Benson Fall 2013 Clemson, Team 14-2, Benson Fall 2013 회원
CLEM-BENSON-F13S14G2
3 회원들
안내서 27개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 9
전체 시간: 498
