이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use a bit driver and a Phillips #0 bit to remove the one 5 mm retaining screw.
Lift the panel up and out of the way.
The RAM chip is secured by two retaining arms that run parallel with the chip. Gently pull these arms in opposite directions off of the chip.
After the retainer arms are free, push the chip towards the top of the netbook. This will free the chip for removal.
Push the replacement RAM into the original position.
Reattach both securing arms onto the sides of the RAM chip.
Place the panel back into the securing slots and let it rest in its original position.
With the bit driver and Phillips #0 bit, secure the panel down with one screw.
다른 한 분이 해당 안내서를 완성하였습니다.
