필요한 것
Save your work.
Turn off the computer. The LED Power must not light up anymore.
Close the screen and place the computer face down as shown in the picture.
Slide the safety latch (on the left side of the picture) to the unlocked position (to the left) to activate the release.
Slide the battery release (pictured on the right) to the right side and hold it to release the battery and remove the battery from the back of the computer.
Remove the 5 marked screws and then turn the device over and open the screen.
First, we remove the cover of the Einschalteinheit by levering each other with a spatula to the left and right.
Grasp the keyboard at the top and on the left side start to lever out the keyboard with a spatula. Repeat this procedure on the right.
Hold the keyboard in this position with one hand and use the other hand and pointed tweezers to open the black retaining clips by sliding them in the direction of the ribbon cable.
Now the ribbon cable can be pulled out of the holder.
Place the keyboard securely on its work surface.
Repeat the steps in order to reassemble your device.
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
irlanda님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
