주요 콘텐츠로 건너뛰기
Toshiba NB255-N250 Memory Replacement
필요한 것
  1. Toshiba NB255-N250 Memory Replacement, Power off the Toshiba NB255-N250: 1 단계, 이미지 2개 중 1개 Toshiba NB255-N250 Memory Replacement, Power off the Toshiba NB255-N250: 1 단계, 이미지 2개 중 2개
    • Before starting any repairs, make sure to power off your device.
    • To shut down the Toshiba NB255-N250, follow the instructions for your operating system or press and hold the power button until the screen turns off.
  2. Toshiba NB255-N250 Memory Replacement, Remove the Battery: 2 단계, 이미지 3개 중 1개 Toshiba NB255-N250 Memory Replacement, Remove the Battery: 2 단계, 이미지 3개 중 2개 Toshiba NB255-N250 Memory Replacement, Remove the Battery: 2 단계, 이미지 3개 중 3개
    • Move the two battery retaining tabs to the opposite sides of the device, then pull the battery straight out the back of the device.
  3. Toshiba NB255-N250 Memory Replacement, Remove The Memory Access Panel Screw: 3 단계, 이미지 1개 중 1개
    • Remove the PH1 screw from the memory access panel.
    • Unlike many other access cover screws on laptops, this screw is not captive.
  4. Toshiba NB255-N250 Memory Replacement, Remove The Memory Access Panel: 4 단계, 이미지 1개 중 1개
    • Use a Metal Spudger or other opening tool to remove the memory access panel.
  5. Toshiba NB255-N250 Memory Replacement, Remove Old Memory: 5 단계, 이미지 2개 중 1개 Toshiba NB255-N250 Memory Replacement, Remove Old Memory: 5 단계, 이미지 2개 중 2개
    • Remove the memory by moving the tabs on the left and right away from the ram.
    • When fully opened, the memory will pop up at a 45 degree angle. Pull the memory straight out by the sides and away from the system.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Charles Myrick
회원 가입일: 10/19/18
270 평판
안내서 2개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 21
전체 시간: 478
