주요 콘텐츠로 건너뛰기
Toshiba NB305 Hard Drive Replacement
필요한 것
  1. Toshiba NB305 Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Place the laptop upside down with the battery facing you.
  2. Toshiba NB305 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Use your right hand to move latch 1 to the right to unlock the battery.
  3. Toshiba NB305 Hard Drive Replacement: 3 단계, 이미지 1/2 Toshiba NB305 Hard Drive Replacement: 3 단계, 이미지 2/2
    • Use your left hand to hold latch 2 to the left.
    • Simultaneously take the battery out with your right hand.
  4. Toshiba NB305 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1/3 Toshiba NB305 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 2/3 Toshiba NB305 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 3/3
    • Locate the two torx T-6 screws on the back of the laptop and remove them.
    • 6mm Torx T-6 screws.
    • 3mm Torx T-6 screws.
  5. Toshiba NB305 Hard Drive Replacement: 5 단계, 이미지 1/1
    • Note that the screw on the left is longer than the screw on the right.
  6. Toshiba NB305 Hard Drive Replacement: 6 단계, 이미지 1/2 Toshiba NB305 Hard Drive Replacement: 6 단계, 이미지 2/2
    • Using spudger, pry the panel up.
  7. Toshiba NB305 Hard Drive Replacement: 7 단계, 이미지 1/1
    • Remove hard drive by pulling to the right and then upward and out.
결론
Nuri Chung
회원 가입일: 10/25/16
368 평판
안내서 3개 작성하였습니다
USF Tampa, Team 5-5, Lacy Fall 2016 USF Tampa, Team 5-5, Lacy Fall 2016 회원
USFT-LACY-F16S5G5
3 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 12
전체 시간: 1,456
