주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Toshiba NB305 Keyboard Replacement
필요한 것
  1. Toshiba NB305 Keyboard  Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Place the laptop upside down with the battery facing you.
  2. Toshiba NB305 Keyboard  Replacement: 2 단계, 이미지 1개 중 1개
    • Use your right hand to move latch 1 to the right to unlock the battery.
  3. Toshiba NB305 Keyboard  Replacement: 3 단계, 이미지 2개 중 1개 Toshiba NB305 Keyboard  Replacement: 3 단계, 이미지 2개 중 2개
    • Use your left hand to hold latch 2 to the left.
    • Simultaneously take the battery out with your right hand.
  4. Toshiba NB305 Keyboard  Replacement, Keyboard: 4 단계, 이미지 2개 중 1개 Toshiba NB305 Keyboard  Replacement, Keyboard: 4 단계, 이미지 2개 중 2개
    • Remove the four F4 screws and the F6 screw underneath battery.
    • 4mm Phillips-0 screws.
    • 6mm Phillips-0 screws.
  5. Toshiba NB305 Keyboard  Replacement: 5 단계, 이미지 3개 중 1개 Toshiba NB305 Keyboard  Replacement: 5 단계, 이미지 3개 중 2개 Toshiba NB305 Keyboard  Replacement: 5 단계, 이미지 3개 중 3개
    • Using a spudger, gently pry out on the plastic cover.
    • Turn it over and remove plastic cover on top of laptop with power button on it.
  6. Toshiba NB305 Keyboard  Replacement: 6 단계, 이미지 2개 중 1개 Toshiba NB305 Keyboard  Replacement: 6 단계, 이미지 2개 중 2개
    • Use the plastic opening tool in little notches above the keyboard
    • Gently pry up on the keyboard until it lifts up.
    • You might hear a click when the keyboard releases.
  7. Toshiba NB305 Keyboard  Replacement: 7 단계, 이미지 1개 중 1개
    • Gently lift the keyboard up toward the screen.
    • Be careful! There is a cable still connected from the computer to the keyboard.
  8. Toshiba NB305 Keyboard  Replacement: 8 단계, 이미지 2개 중 1개 Toshiba NB305 Keyboard  Replacement: 8 단계, 이미지 2개 중 2개
    • The ribbon cable has a clip on each side holding it to the motherboard.
    • Using a spudger, press on the clips to release the cable.
    • The cable will slide out on its own when it is properly released.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Nuri Chung
회원 가입일: 10/25/16
377 평판
안내서 3개를 작성함
USF Tampa, Team 5-5, Lacy Fall 2016 USF Tampa, Team 5-5, Lacy Fall 2016 회원
USFT-LACY-F16S5G5
3 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 22
전체 시간: 990
