주요 콘텐츠로 건너뛰기
Toshiba NB305 Wifi Card Replacement
필요한 것
  1. Toshiba NB305 Wifi Card Replacement, Battery: 1 단계, 이미지 1/1
    • Place the laptop upside down with the battery facing you.
  2. Toshiba NB305 Wifi Card Replacement: 2 단계, 이미지 1/1
    • Use your right hand to move latch 1 to the right to unlock the battery.
  3. Toshiba NB305 Wifi Card Replacement: 3 단계, 이미지 1/2 Toshiba NB305 Wifi Card Replacement: 3 단계, 이미지 2/2
    • Use your left hand to hold latch 2 to the left.
    • Simultaneously take the battery out with your right hand.
  4. Toshiba NB305 Wifi Card Replacement, Wifi Card: 4 단계, 이미지 1/3 Toshiba NB305 Wifi Card Replacement, Wifi Card: 4 단계, 이미지 2/3 Toshiba NB305 Wifi Card Replacement, Wifi Card: 4 단계, 이미지 3/3
    • Locate the two torx T-6 screws on the back of the laptop and remove them.
    • 6mm Torx T-6 Screws
  5. Toshiba NB305 Wifi Card Replacement: 5 단계, 이미지 1/2 Toshiba NB305 Wifi Card Replacement: 5 단계, 이미지 2/2
    • Using a spudger pry the panel up.
  6. Toshiba NB305 Wifi Card Replacement: 6 단계, 이미지 1/2 Toshiba NB305 Wifi Card Replacement: 6 단계, 이미지 2/2
    • Using a spudger pry up and off the two wire connections.
    • Note that the black wire is on the top of the card and the white is the bottom.
  7. Toshiba NB305 Wifi Card Replacement: 7 단계, 이미지 1/2 Toshiba NB305 Wifi Card Replacement: 7 단계, 이미지 2/2
    • Remove the two Phillips 0 size screws on WIFI card.
    • Once the screws are removed the WIFI card will raise up
  8. Toshiba NB305 Wifi Card Replacement: 8 단계, 이미지 1/2 Toshiba NB305 Wifi Card Replacement: 8 단계, 이미지 2/2
    • Grip both sides of the wifi card with your hand.
    • Lift up on the card and pull the card out of the slot
결론
Mateo Fontana
회원 가입일: 09/14/16
286 평판
안내서 2개 작성하였습니다
USF Tampa, Team 5-5, Lacy Fall 2016 USF Tampa, Team 5-5, Lacy Fall 2016 회원
USFT-LACY-F16S5G5
3 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 6
전체 시간: 428
