주요 콘텐츠로 건너뛰기
Toshiba Portege 3110CT Keyboard Replacement
필요한 것
  1. Toshiba Portege 3110CT Keyboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • Begin by removing the battery and flipping the laptop over to see the screws
    • Using a phillips head screwdriver to remove the screws that secure the back
  2. Toshiba Portege 3110CT Keyboard Replacement: 2 단계, 이미지 1/1
    • Flip the laptop back over and open it up carefully
    • Lift up the bottom panel where the mouse click buttons are
    • Lift up slowly as simply flip it up and rest it on the keyboard as not to damage the ribbon cable connecting it
    • Using the spudger disconnect the ribbon cable connected to the bottom of the panel
  3. Toshiba Portege 3110CT Keyboard Replacement: 3 단계, 이미지 1/1
    • Using the same size phillips as before remove the two screws that hold the keyboard in place
    • Lift the keyboard up and slide it downwards and out.
결론
Spencer Gamble
회원 가입일: 10/20/16
401 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 6-4, Martin Fall 2016 UMass Dartmouth, Team 6-4, Martin Fall 2016 회원
UMASSD-MARTIN-F16S6G4
3 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 7
전체 시간: 319
