주요 콘텐츠로 건너뛰기
Toshiba Portege 3110CT Laptop Screen Replacement
필요한 것
  1. Toshiba Portege 3110CT Laptop Screen Replacement, Laptop Screen: 1 단계, 이미지 1개 중 1개
    • Begin by removing the battery and flipping the laptop over to see the screws
    • Using a phillips head screwdriver to remove the screws that secure the back
  2. Toshiba Portege 3110CT Laptop Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Flip the laptop back over and open it up carefully
    • Lift up the bottom panel where the mouse click buttons are
    • Lift up slowly as simply flip it up and rest it on the keyboard as not to damage the ribbon cable connecting it
    • Using the spudger disconnect the ribbon cable connected to the bottom of the panel
  3. Toshiba Portege 3110CT Laptop Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Using the same size phillips as before remove the two screws that hold the keyboard in place
    • Then simply lift the keyboard up and slide it down and out
  4. Toshiba Portege 3110CT Laptop Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Using the phillips remove the 3 screws that hold the screen mount to the rest of the keyboard
    • Once you remove the final screw be careful as the screen will want to fall back to prevent damage
  5. Toshiba Portege 3110CT Laptop Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Pull the screen off the rest of the laptop and flip it over
    • Using the phillips screw driver remove the final 3 screws securing the screen
결론
작성자
2다른 기여자 명과 함께
Ashley Furtado
회원 가입일: 10/20/16
101 평판
안내서 1개를 작성함
UMass Dartmouth, Team 6-4, Martin Fall 2016 UMass Dartmouth, Team 6-4, Martin Fall 2016 회원
UMASSD-MARTIN-F16S6G4
3 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 24
전체 시간: 646
