주요 콘텐츠로 건너뛰기
Toshiba Portege M300 Hard Drive Replacement
필요한 것
  1. Toshiba Portege M300 Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the computer over onto its back.
  2. Toshiba Portege M300 Hard Drive Replacement: 2 단계, 이미지 1/2 Toshiba Portege M300 Hard Drive Replacement: 2 단계, 이미지 2/2
    • Slide the lock on the left side to the unlock position.
    • Slide the lock on the right side to the unlock position until there is a clicking sound.
  3. Toshiba Portege M300 Hard Drive Replacement: 3 단계, 이미지 1/2 Toshiba Portege M300 Hard Drive Replacement: 3 단계, 이미지 2/2
    • Remove the battery by sliding it away from the laptop.
    • Make sure the two locks from the previous step are in the unlocked position while sliding the battery away.
  4. Toshiba Portege M300 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1/3 Toshiba Portege M300 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 2/3 Toshiba Portege M300 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 3/3
    • Turn the computer over onto the back.
    • Use a Phillips #1 screwdriver to remove the screw from the hard drive cover.
    • Lift and remove the cover.
  5. Toshiba Portege M300 Hard Drive Replacement: 5 단계, 이미지 1/3 Toshiba Portege M300 Hard Drive Replacement: 5 단계, 이미지 2/3 Toshiba Portege M300 Hard Drive Replacement: 5 단계, 이미지 3/3
    • Carefully remove the hard drive from the IDE cable by pulling on the black connector.
    • Do not pull the orange cable.
  6. Toshiba Portege M300 Hard Drive Replacement: 6 단계, 이미지 1/2 Toshiba Portege M300 Hard Drive Replacement: 6 단계, 이미지 2/2
    • Remove the two gray rubber covers from both ends of the hard drive.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Alison Wendt
회원 가입일: 04/18/13
135 평판
안내서 6개 작성하였습니다
Cal Poly, Team 21-51, Johann Spring 2013 Cal Poly, Team 21-51, Johann Spring 2013 회원
CPSU-JOHANN-S13S21G51
3 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 2,378
