소개
This guide goes through the steps needed to install a new keyboard. Attention to detail is required in order to reverse the steps for instillation of a new keyboard, returning each screw to the correct location.
  1. Turn the computer over onto its back.
    • Turn the computer over onto its back.
  2. Slide the lock on the left side to the unlock position. Slide the lock on the right side to the unlock position until there is a clicking sound.
    • Slide the lock on the left side to the unlock position.
    • Slide the lock on the right side to the unlock position until there is a clicking sound.
  3. Remove the battery by sliding it out while both locks remain in the unlock position. Remove the battery by sliding it out while both locks remain in the unlock position.
    • Remove the battery by sliding it out while both locks remain in the unlock position.
  4. Use a plastic opening tool to unsnap the right hand side speaker cover. Use a plastic opening tool to unsnap the right hand side speaker cover.
    • Use a plastic opening tool to unsnap the right hand side speaker cover.
  5. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  6. Remove the rest of the cover by sliding it to the right and lifting the edge. Remove the rest of the cover by sliding it to the right and lifting the edge.
    • Remove the rest of the cover by sliding it to the right and lifting the edge.
  7. Use a Phillips head #00 screwdriver to remove the two silver screws at the top of the keyboard. Two 4.0 mm coarse thread screws.
    • Use a Phillips head #00 screwdriver to remove the two silver screws at the top of the keyboard.
    • Two 4.0 mm coarse thread screws.
  8. Remove the Torx screw holding the left keyboard tab in place, and lift it to release. One Torx T6 fine thread screw. One Torx T6 fine thread screw.
    • Remove the Torx screw holding the left keyboard tab in place, and lift it to release.
    • One Torx T6 fine thread screw.
  9. Turn the computer over on to the back. Remove the middle screw with a Phillips head #000 screwdriver.
    • Turn the computer over on to the back.
    • Remove the middle screw with a Phillips head #000 screwdriver.
    • One 7.5 mm fine thread screw.
  10. Turn the computer over to the front. Gently pull at the top and bottom to remove the keyboard.
    • Turn the computer over to the front.
    • Gently pull at the top and bottom to remove the keyboard.
    • Peel off the black tape that holds the connection wire.
  11. Flip the keyboard over and carefully unplug the connection wire. Reverse the steps for proper instillation of the new keyboard.
    • Flip the keyboard over and carefully unplug the connection wire.
    • Reverse the steps for proper instillation of the new keyboard.
결론
Alison Wendt
회원 가입일: 2013년 04월 18일
78 평판
안내서 6개 작성하였습니다
Cal Poly, Team 21-51, Johann Spring 2013 Cal Poly, Team 21-51, Johann Spring 2013 회원
CPSU-JOHANN-S13S21G51
3 회원들
안내서 6개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 6
전체 시간: 948
