주요 콘텐츠로 건너뛰기
Toshiba Portege M300 LCD Replacement
필요한 것
  1. Toshiba Portege M300 LCD Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the computer over onto its back.
  2. Toshiba Portege M300 LCD Replacement: 2 단계, 이미지 1/2 Toshiba Portege M300 LCD Replacement: 2 단계, 이미지 2/2
    • Slide the lock on the left side to the unlock position.
    • Slide the lock on the right side to the unlock position until there is a clicking sound.
  3. Toshiba Portege M300 LCD Replacement: 3 단계, 이미지 1/2 Toshiba Portege M300 LCD Replacement: 3 단계, 이미지 2/2
    • Remove the battery by sliding it away from the laptop.
    • Make sure the two locks from the previous step are in the unlocked position while sliding the battery away.
  4. Toshiba Portege M300 LCD Replacement, LCD: 4 단계, 이미지 1/2 Toshiba Portege M300 LCD Replacement, LCD: 4 단계, 이미지 2/2
    • Use a plastic opening tool to unsnap the right hand side speaker cover.
  5. Toshiba Portege M300 LCD Replacement: 5 단계, 이미지 1/2 Toshiba Portege M300 LCD Replacement: 5 단계, 이미지 2/2
    • Remove the rest of the cover by sliding it to the right and lifting the right edge.
  6. Toshiba Portege M300 LCD Replacement: 6 단계, 이미지 1/2 Toshiba Portege M300 LCD Replacement: 6 단계, 이미지 2/2
    • Remove all eight plastic circular covers on the plastic screen bezel.
    • Only seven of these plastic covers will contain screws underneath.
    • Unscrew all seven screws with a Phillips head #000 screwdriver.
  7. Toshiba Portege M300 LCD Replacement: 7 단계, 이미지 1/2 Toshiba Portege M300 LCD Replacement: 7 단계, 이미지 2/2
    • Use a plastic opening tool to separate the screen bezel from the rest of the case.
    • Pull at the top edge of the LCD to separate it from the top part of the case.
    • Only separate the casing and the LCD by an inch—there are still wires connecting them.
  8. Toshiba Portege M300 LCD Replacement: 8 단계, 이미지 1/2 Toshiba Portege M300 LCD Replacement: 8 단계, 이미지 2/2
    • Use a Phillips #000 to unscrew the one 2.8 mm fine thread screw holding the wire connected to the right face of the LCD.
  9. Toshiba Portege M300 LCD Replacement: 9 단계, 이미지 1/1
    • Flip the LCD over onto the back.
    • Gently pull the connection on the corner of the LCD to disconnect.
  10. Toshiba Portege M300 LCD Replacement: 10 단계, 이미지 1/2 Toshiba Portege M300 LCD Replacement: 10 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Remove the tape connecting LCD to the inverter.
    • Use tweezers to remove the LCD cable from the inverter.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alison Wendt
회원 가입일: 04/18/13
135 평판
안내서 6개 작성하였습니다
Cal Poly, Team 21-51, Johann Spring 2013 Cal Poly, Team 21-51, Johann Spring 2013 회원
CPSU-JOHANN-S13S21G51
3 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 16
전체 시간: 1,009
